What can I get with my analogue decoder?
Information exchange on analogue satellite systems
Old 26-09-2008   #1
My System: 43cm @ 19.2 with mVision USB PVR, 1.1m Fortec Star @ 5e and 1w with Kworld DVB-S2 Card and a Viasat receiver
Talking What can I get with my analogue decoder?
No this isnt a question thread. It's a answer thread.
Basicly because of the way the sattelites where back when the decoders were made, it stops them reciving some channels.
I know for a fact that the Amstrad SRD series are not capable of reciving anything over 11421 H (Nick).
I am asking for owners of other analogue recivers that CANNOT go over
11421 H to post them here. That way we will have a list of what can reciver what.
iandoh is offline   Reply With Quote
Old 26-09-2008   #2
Site administrator
Analoguesat's Avatar
Any of the really old boxes designed for 10000MHz lnb's will have this problem when used with modern 9750MHz lnb's.
From a few years ago
_http://www.selkirkshire.demon.co.uk/analoguesat/amstradsrd400.html
Analogue forever!
Old 26-09-2008   #3
satelliteman's Avatar
Real name: Paul
Early Ku band 10.9Ghz - 11.7Ghz down converted to early receivers tuning range was 950Mhz - 1700Mhz using a 10Ghz LNb, all fell in place nicely.
Remember the frequency shifters used with 10Ghz LNb's when services started down on 10.7Ghz due to tuner range A/S ?
We sold a fair few of them at the time.
satelliteman.
An Installers Choice
Follow us on
Old 26-09-2008   #4
rolfw's Avatar
Real name: Rolf
I've probably still got one of them sitting in a deep box in the garage, along with a 22Khz switch, you can still get the 22Khz switches on the net, although Global don't make them anymore.
Rolf
Old 26-09-2008   #5
Real name: Paul
If my quick calculations with the current downlink are correct, using an early original receiver with a tuning range of 950Mhz to 1700Mhz mixed with a 9.75Ghz LNb, the receiver will not be able to see anything between 1700Mhz to 1950Mhz......
Yes, the ADX also shifted the higher transponders over 2200Mhz if not turned off, way way out of the tuning range of older receivers.
Universal, so simple now
satelliteman.
Follow us on
Old 26-09-2008   #6
So there is no way to shift the signals with a channel expander?
Old 26-09-2008   #7
rolfw's Avatar
Real name: Rolf
From memory, the channel expander can be adapted to shift LO up or down 250Mhz, so effectively expanding your tuner range by 500Mhz.
Rolf
Old 26-09-2008   #8
Real name: Paul
Yep, able to move 'IF' up or down by 500Mhz into a 950 - 1700Mhz tuner range
satelliteman.
Follow us on
Old 26-09-2008   #9
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
That's how I get my old Metrix VX600 analogue speccy to see above 1700MHz
It's a pain to convert the digital readout to the true frequency though. Never mind, I'm adept at recognising the satellites on the spectrum display
Real time display is invaluable though for anything new that may pop up on a satellite.
Llew is offline   Reply With Quote
Old 26-02-2009   #10
My System: Technomate 1500ci + super , motorised 90cm triax , sky freesat uk
Is there any way i can make my amstrad srd 2000 to get TF1 on 5w ?
mariust5 is offline   Reply With Quote
Old 26-02-2009   #11
Site administrator
Probably not - TF1 is way off the top of the Astra 1 frequency range, and thats a pretty old receiver.
Analogue forever!
Old 26-02-2009   #12
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
I think we used to get it 'just' with a.. er 'fix'.. when we supplied French channels to some properties years ago ..... I think it was quite noisy though.. visually and sound wise .. being so high.
pedro2000uk is offline   Reply With Quote
Old 26-02-2009   #13
If only there was a list on what receivers work/don't work with these high frequencies . Will a digital/anlogue combo box get them or are there some that do and some that don't ? I would than know for certain what to get and not waste my time and money .
Old 26-02-2009   #14
My System: pace 2500B sky digibox, zone 1 sky minidish
what kind of fix?
i have a SRX 200 that sees little use and having the french channels would be quite nice
also there's a dish i realigned for an old french lady in my town that has an
LNB with the words TELECOM on it and looks to have a LO of 11.7 if my memories correct
ltkltkltk is offline   Reply With Quote
Old 26-02-2009   #15
High band LNB should do ... still might be low for TFI hence the noise above 12700- (have to look up my lnb freqs') ... we had a French tenant, an electronics engineer grad / student- he couldn't change a light bulb, but could er.. mess. (*seriously... he didn't know about bayonet fittings).
Old 04-03-2009   #16
Well , i managed to make the amstrad get TF1 with the use af an ADX , the picture and sound is indeed very noisy and sparkly , but watchable . Will a proper receiver for this frequency show the same symptoms or show the picture clearly ?
Old 04-03-2009   #17
Site administrator
You will get a better picture, although the French channels are notorious for having some sparklies on them
Analogue forever!
Old 12-03-2009   #18
Tested with a Manhattan dsr-2500 apci and is coming in loud and clear , turns b&w after the banner goes out but i think my telly it's not multisystem .
Old 12-03-2009   #19
Site administrator
It might be worth scarting the signal through a dvd player / recorder if you have one - some of them are multi system and happily transcode the secam signals to UK PAL.
Analogue forever!
Old 15-05-2009   #20
My System: metronic touchbox2 , thomson dsi23
try a quatro lnb
a quatro lnb has a high v and high h connector start frequency at 11700 mhz might be worth a try
michaelmachine is offline   Reply With Quote
Old 18-05-2009   #21
I can now confirm that the Pace prima and the Jvc tu-c200 work on TF1 with a few sound issues . i have set the left = 5.79 and the right = 6.37 and it's ok-ish . What frequencies shall i use to get the proper sound ?
Old 18-05-2009   #22
Site administrator
Its 5.80 mono
Analogue forever!
The Following User Says Thank You to Analoguesat For This Useful Post:
mariust5 (19-05-2009)
analogue, decoder
