Use a digital LNB for analog reception ?Information exchange on analogue satellite systems | |
| Young one with a hobby Join Date: 29-05-2008 Location: West london and La coruna Spain
My System: Motorised setup 68cm penta digit 45e - 30w |
Hi I have been given a Pace mss 100 i! can i connect my exting dish with digital LNB pointing at astra 1 to it or will i neeed a analog LNB ? Thanks Mark | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | It will be ok. Universal is exactly that, having a 9.75 & 10.6 local oscillator. Without a 22KHz tone from the receiver to switch the LNb into the high band, the LNb will remain in low band (9.750) and will receive an IF signal from 950 -1950MHz. | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | kenny1234 (09-04-2009) |
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | The MSS100 has the ability to use a Universal LNB as it has tone switching, so you're good to go... ![]() And a little note; There's no difference between an LNB used for Analogue or Digital, the only differences are whether they are the ancient 10GHz LNB, an Enhanced 9,750MHz LNB or Universal 9,750/10,600MHz LNB. All this nonsense about calling them Analogue, Digital or HD is just sellers trying to sell you something that you don't actually need... | ||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Did wonder whether it had an LNb setting adjustment. It's been a while | ||
| | #5 | ||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | | ||
| | #6 | ||
My System: Motorised setup 68cm penta digit 45e - 30w | I had done it and it worked fine some sparklys on some channels, that could be down to dish size but other then that is was all ok | ||
| | #7 | |||
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | A 60cm dish in good weather on Astra 19.2e should not really have any sparklies. | |||
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | ||||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Sparklies can be purely down to frequency variations on LNBs, so if the channels were fine tuned on an old LNB, but then connected to a new LNB, the LO may be slightly different, also worth checking skew. | ||
| | #9 | ||
My System: Motorised setup 68cm penta digit 45e - 30w | I had alot of dead channels because i can't scan as i have no remote . so using the power button and up and down buttons :P the rear F connection is different aswell i don't know why :S so push the plug in with some black pvc tape sorted . Over 200 channels where stored on the system including sky 1 when it was on astra 1 :P Im now trying to get a free used skydigi box, probs one of the early ones :P, already have a sky + and i have a sky HD just need the old digi box . Mark | ||
| Last edited by Markjose; 12-04-2009 at 07:52 PM. Reason: Spelt name wrong wrote makr when spose to write mark | |||
| | #10 | ||
| | #11 | ||
My System: Motorised setup 68cm penta digit 45e - 30w | Thanks 2Cvbloke i just have orded 2 but why sell in pairs ? Just incase the wife takes one away you always got a spare :P I had found a Digibox up in my dads loft with 5 sky remotes nice | ||
| | #12 | |||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | ![]() Or they just had to get rid of them... | |||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | ||||
| | #13 | ||
My System: Motorised setup 68cm penta digit 45e - 30w | Once i get the remote and i will put some pictures up of the sytem display and of 19.2 analog | ||
| analog, digital, lnb, reception |
