No sound on "New analogue" receiver ?
Information exchange on analogue satellite systems
Old 01-06-2009   #1
My System: 1m dish currently pointing at 5 degrees W to get French channels
I just bought (off Ebay, of course) a used Hirschmann CSR601 analogue receiver, which I've hooked up to my dish pointing at 5W. My digital receiver happily gets all the French stuff from there, so I think the alignment's good.
When I connect up the analogue box, I get pictures, not too speckly from the couple of channels I've tried so far, but NO SOUND, just a hissing.
So, is there some reason this might be happening - LNB skew, alignment, cabling, or something else; or is my receiver busted ?
Any ideas, I'd be grateful (hope I've not just wasted £2.20 on the box :-) )
Andy
andydsmith is offline   Reply With Quote
Old 01-06-2009   #2
Site administrator
Analoguesat's Avatar
The French channels use the audio sub carrier 5.8MHz (mono transmission). Most analogue receivers come with 7.02-7.20 (stereo) as default so try changing the audio settings.
Analogue forever!
Old 01-06-2009   #3
Real name: nelson
My System: Strong 4375 - 1.8 channel master offset - inverto 0.3 C120 twin and pauxis C band l.n.b.,s - Vantage X221S CI usb - skystar 2 pc card - Technomate 1500 CI super - + fixed dishes
hi
i,m not sure how to navigate the menu ,s on that reciever
but have you tried all the audio options -- i,v just looked on flysat
and most of the analogue cahnnels on 5 west need setting to audio option -- 5.80
good luck
nelson_b
edit -- you beat me to it analoguesat l.o.l
nelson_b is offline   Reply With Quote
Old 01-06-2009   #4
Mod and septic resident
Channel Hopper's Avatar
Or the receiver has a modulator set to PAL G, and the UK TVs are all PAL I. Using a SCART lead should over come this.
Old 02-06-2009   #5
Thanks for the advice. The box is connected through a scart lead, and I've also tried the seperate audio outputs, same results. I'll have a play this afternoon to see if I can find the audio setting and change the audio setup to the right frequency.
I'll let you know how I get on - no manual for the box....
Cheers
Andy
Old 02-06-2009   #6
Problem solved, thanks for the help
Well, it wasn't easy, given that my German is about 25 years out of date, but I managed to find a pdf manual and decipher it enough to find how to set the audio to the right frequency, and mono.
That worked a treat, thanks guys.
Andy
Old 02-06-2009   #7
Site administrator
Excellent - thanks for letting us know
Analogue forever!
new analogue, receiver, sound
