what analouge receiver,is compatible with drake earthstation aps 4240 E remote antenaInformation exchange on analogue satellite systems | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! i have a drake aps 4240 E antenna remote controll system,was,part of my 2.20 Tagra Dish,that i bought 4 years ago! a picutre of the device you can see here _http://www.aurtek.se/Antenna%20steering%20and%20analogue%20receiver.jpg this analouge receiver,on the picture,i also have,it comes,from kathrein,but the remote is also missing..! on the back side this heavey box has a lot of connections for e.g lnb in ,to rvcr to rvr from lnb polarizer gain controll ,normal m1 m2 etc weight around 5 kg! now i dont know ,how i can connect this device,and what analouge receiver is needed? is this a montery on the picture? i dont know this type! the problem,i have no remote for! when i look on Ebay this looks like a profesional system,that used maybe 15 years ago,but without remote,maybe i can not use it.. or a master analouge receiver,controlls it,like a slave box? there are so many types of drake earthstations on Ebay maybe a usa member knows it | ||
| 4240, analouge, antena, aps, compatible, drake, earthstation, receiver, remote |
