replacing systemsettings memory eprom or battery,in echostar lt 8700?Information exchange on analogue satellite systems | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! yesterday,after a heavey lighting,i disconect the power from my pc room,now my lt 8700,where i move,my egis rotor,over dvb 2000,and the comort,lost his memory,and shows please set east limit not on sat! now,i should know,how i can synchroneized it again ! and the technical part,what type,of battery akku type ,or eprom inside,is needed to replace,that after interrupting the power,nothing happens again? | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The battery in my Echostar SR8700 is the normal +3V cell (DL2430). Likely to be the same in the LT8700. I think they changed the EEPROM type in the LT, so might not be able to help there. Llew | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! i replace now ,the barttery.wirth the right type varta CR2430 3 V but i recogneized,that it not solve the problem,the memory,is lost again and shows no sat,after power interrupt,would could be the other faults,that i could check when its not the battery? | ||
| 8700, battery, echostar, eprom, memory, replacing, systemsettings |
