Analogue dish collar clamps
Information exchange on analogue satellite systems
Old 07-10-2009   #1
skydish's Avatar
My System: Sky minidish, Thomson Digibox Hoping to bring an old analogue dish back to life on 28.2 in the near future!
Cool Analogue dish collar clamps
Are the old analogue sky dish collor clamps good for modern LNB's? (As i've mentioned before I am planning to re-use one for 28.2E)
skydish is offline   Reply With Quote
Old 07-10-2009   #2
Site administrator
Analoguesat's Avatar
Minidish lnb's are optimised for the oval minidish design.
Whilst it would work ok with the strong Astra2 signals it will be something less than optimal on a weak signal as it will not pick up full illumination.
Thats the theory anyway - you never know what will work for you
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 07-10-2009   #3
skydish's Avatar
Hmm... I guess i'll just have to see if the universal quad I am getting from Ebay will fit on the 80cm dish I am going to rescue from the back of my friends house. (before it goes in a skip!)
Sorry for straying off topic...
Old 07-10-2009   #4
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
It should do if you burr off the ridges around where the collar will go.
No problemo!
Tivù is online now   Reply With Quote
The Following User Says Thank You to Tivù For This Useful Post:
skydish (07-10-2009)
Old 07-10-2009   #5
skydish's Avatar
Oh right, thanks, do you think I will get a decent signal in comparison to the minidish?
Old 07-10-2009   #6
Tivù's Avatar
Real name: Gordon
Stonking
Old 07-10-2009   #7
skydish's Avatar
Fantastic!
Old 07-10-2009   #8
Site administrator
Ive split this off the other topic as it deserves its own discussion :
Analogue forever!
Old 07-10-2009   #9
skydish's Avatar
Yeah and one I am very interested in, I am hoping that I can fit the quad onto the 80cm dish and run 6 feeds off it, 2 for sky+ in the lounge and a single feed each for the 4 bedrooms, with the larger dish I hope to gain a better signal strength and less viewing disruption in bad weather.
All this will happen once I have taken the dish off my friends house and restored it, which should be soon.
Old 07-10-2009   #10
Site administrator
A quad wont work if you want 6 feeds! You will need an octo if you want just the one dish
Analogue forever!
Old 07-10-2009   #11
Site administrator
Make sure you spray all the clamp bolts with wd40 a couple of days before you want to do any work on the dish & dont be afraid to hacksaw through anything rusted solid!
Bolts can be replaced easily enough
Analogue forever!
Old 07-10-2009   #12
skydish's Avatar
The LNB I have seen has 6 feeds, not sure what its called so I just referred to it as a quad, Lol, Yes I will use WD40, I plan to replace all the bolts and screws etc anyway so I will probably be getting the hacksaw out.
Old 07-10-2009   #13
rolfw's Avatar
Real name: Rolf
I have never seen, nor heard of a 6 feed LNB, have you got a link to it?
If you have, disable it by putting an underscore before the HTTP like so: _http.www
Rolf
Old 07-10-2009   #14
skydish's Avatar
I've just looked and it actually has 8 feeds and is indeed called an octo. Bonus!
Old 07-10-2009   #15
Tivù's Avatar
Real name: Gordon
Just as well this is effectively a new installation, then - Octos are moderately heavy compared to a single and can flex the arm down a tiny bit.
Although the old "Analogue" dish probably has a tubular arm so is inherently rigid as compared to the rectangular section of a Toydish, you'd still have had to take this into account for a retrofit.
But as it isn't a retrofit, it'll all come out in the wash when you align the Dish anyway.
Old 07-10-2009   #16
skydish's Avatar
Luckily the dish is one that has support arms coming down from either side of the dish and connects with the end of the LNB arm, so hopefully I should get away with that. Lol
Old 07-10-2009   #17
Tivù's Avatar
Real name: Gordon
Nice. That'll stop the end of the arm being displaced in moderate winds.
Old 07-10-2009   #18
Mod and septic resident
Channel Hopper's Avatar
Then you have a real ancient one. Check the reflector has no signs of severe reflector corrosion. If it is a solid white dish then tap the back all round to check for internal damage.
Old 07-10-2009   #19
skydish's Avatar
It was new in 1992, looks sound from ground level, I shall be rubbing the dish down and respraying it once I get it down.
Old 08-10-2009   #20
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards
..This is gonna make you cry ...
I sent 3 of these old sky analogue dishes to their final resting place last weekend ..one of which was actually still in use up to 3 weeks ago..when I took it off my dads wall ...and replaced it with a motorised 80cm..
2 of the scrappers were lattice types with holes in the reflector and one was a solid amstrad..
may they rest in pieces.
great dishes in their day...but my garden was starting to look like a scrapyard.
I kept all the old lnbs though ...
..well you never know when you might need a paperweight..
Vipersan is online now   Reply With Quote
Old 08-10-2009   #21
skydish's Avatar
Oh what a shame, the old dishes had so much more character than the newer mini dishes. The one I am getting is the black perforated dish, I was going to get the white one but cannot find one in decent condition unfortunately. (unless I go knocking on strangers doors! Lol)
analogue, clamps, collar, dish
