SamY 65 on Motorhome
Thread Tools Display Modes
Old 20-05-2004   #1
Question SamY 65 on Motorhome
I have a problem:
Please try to help with the current problem. We have not used the SamY for some time and now when we switch on the Satellite Dish raises to a fully upright position then stops WITHOUT starting to seek for satellites. The control panel on/off red light stays flashing and the dish will not move even when the manual buttons or alternative satellite buttons are pressed. In fact the only way to lower the dish is to turn off the 12V then turn it back on again! All cables are correctly connected and the analogue receiver show the channel numbers on the TV as well as the menu etc.
Any help would really be appreciated as we have fitted the new sky minibox and would really like to use it with the SamY system on our holiday to France next week!
I await any comments/help.
garyelliott is offline   Reply With Quote
Old 20-05-2004   #2
rolfw's Avatar
Afraid that I haven't had any experience of the auto-seeking model Gary, looked at another member's manual search system a short while back though.
Unfortunately, it sounds like the unit may need reprogramming.
__________________
Rolf
Donate
Old 21-05-2004   #3
Question
Rolfe,
Are there any satellite dealers that could reprogram/fix it near Watford Hertfordshire?
Gary
Old 21-05-2004   #4
rolfw's Avatar
Sorry Gary, I hadn't heard of the unit until Peter posted in the other thread, they only seem to be on imported vehicles as satellite on motorhomes is not as common here as it is in perhaps Germany.
__________________
Rolf
Donate
Old 21-05-2004   #5
Smile
Ok, thank anyway.
You don't think is likely to be mechanical then?
It worked fine last time we used it.
Gary
Old 21-05-2004   #6
rolfw's Avatar
It could be mechanical, when you switch it on you should perhaps listen for attempted activity at the dish. If you power down when the dish is raised and then power up again, can you then move it manually?
__________________
Rolf
Donate
Old 21-05-2004   #7
Wink
No I cannot move it once it is in the raised position. It used to start turning and lifting as it searched for the satellite but now it just raises and stops. I am suspisious about the on/off light on the SAT-Finder box flashing as I am sure it used to stop once the dish was raised.
gary
Old 21-05-2004   #8
rolfw's Avatar
Perhaps there is something in the dish mechanism, preventing it form locking up fully, may be worth probing this.
__________________
Rolf
Donate
Old 21-05-2004   #9
Red face
I will have another look!
Gary
Old 02-06-2008   #10
My System: samy 65 satellite syatem
Smile
Hi, i have just joined the forum and read your problem! I have just purchased a second hand samy 65 system and had a similar problem to yours! I contacted conrad anderson who supply them and said that ours would need to be re-programmed. The closest place was Birmingham who do this. Also, can i ask if you still have your manual for yours, and if so, do you know where i could pick one up.
Many Thanks
Karen
karenhowkins is offline   Reply With Quote
Forum Jump
Similar Threads
Anyone heard of a SAMY Satellite Dish peterwilson DISH SETUP: Single sat, Multi-Sat & Motorised systems 25 19-08-2008 09:53 PM
