BSB minidish | |
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
Ive picked up a BSB minidish - a dish not a squarial - still boxed! from fleabay for a fiver. Anyone know what the lnb lo frequency is as I have to try it! (Its the type with the lnb shaped like a spike if that helps) Last edited by Analoguesat; 28-02-2006 at 12:29 PM | ||
| Specialist Contributor Join Date: 01-01-2000 Location: England
My System: 28e, 19e, 13e, 30w | Can't help you with your enquiry Analoguesat but FWIW I had that in my Items Watched thingy on Ebay I'll be very interested to hear how you get on. | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | I'll put some pics up later. Its a most peculiar shape - like a square with the "corners" rounded off.And no its not a ruddy squarial! | ||
| | #4 | |||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Indeed come to think of it I may still have one in the garage
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
| | #5 | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | The lnb was still ensconsed in the polystyrene packing :-) Its probably got a horrible noise level, but might connect it up to one of the just about wrecked old analogue receivers at the weekend and see if anything blows before I put it on the Pace! I can always try a modern lnb at the focal point as a fall back | ||
| | #6 | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | It works - just about ![]() Got a weak signal off one of the 5W analogue channels, after a bit of tinkering. Had to set the lnb frequency to 10600, and detune the receiver as the BSB LNB lo frequency is 10770MHz. This of course puts the tuning way out, but I got a definite confirmation of Canal+ before the encroaching cold drove me back inside. More tinkering when the weather warms up a bit! | ||
| | #7 | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Heres the proof, you can just about make out a scrambled Canal+ signal. I reckon thats a pretty good result- Im using a too small dish with a lousy lnb on it which is circularly polarised instead of linear, and I can get French TV on it : Last edited by Analoguesat; 05-03-2006 at 07:28 PM | ||
| | #8 | ||
You've done well there.... Purely for nostaligic purposes of course. Yes the circular polarisation will be causing a tad of a problem however you can modify the horn to make it receive vertical using a some kitchen chopping board so I understand
| | #9 | ||
| Member Join Date: 04-03-2005 Location: Durham
My System: TV: Freeview (for now!) PC: Athlon XP 2400+, 1GB RAM, 80GB Hard Disk, 128MB GeForce FX Graphics Card | Very impressive! Are you going to try it with digital in the future? Would it work even?! | ||
| | #10 | |||
| | #11 | ||
| Member Join Date: 26-09-2005 Location: Scotland
My System: Technomate 5000adip Fibo 1.2dish Mesh Computer with Skystar 1 card | I have a BSB squarial I used to play about with. Not much use for it now. I had attached it to a concrete block. It is now part of a rockery in the garden as I did not want to part with it, a reminder of when I first got into satellite. | ||
| | #12 | |||
Any chance of a pic? | |||
| | #13 | |||
| Guest
Posts: n/a
| those dishes are very good and i would say better than any same size dish out there today, those lnbs are good for RHC & they also can be converted to LHC you can convert & pick up H & V channels with it but they won't work that good as the waveguide is to small for H & V Also there is a nice new bsb squarial here Vintage-Collectors-Item-Dmac-BSB-SQUARIAL-NEW And a used one here ATV-Antenna-RARE-BSB-SQUARIAL ANALOUGUESAT can the lnb in the squareial be changed to a diffrent type or is it some type of special lnb in it just made to fit the squareial
| | #14 | ||
| Satellite Jumper Join Date: 14-08-2005 Location: Essex, UK
My System: Analogue FTA - Maspro ST9, Sky Digibox - Amstrad DRX100(no subscription), Digital FTA - Manhattan Plaza ST100 with motorised 98CM dish. | I'll hazard a guess that the LNB bracket is custom made for that LNB, am i right in assuming its a Grundig as i have one that looks the same that came with one of my spare dish's. | ||
| | #15 | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | The squarial lnb is effectively a plastic sheet inside the unit. No chance whatsoever of changing it for a different type. That new squarial -25 quid buy it now - plus 15 quid postage. Ouch | ||
| | #16 | |||
Or is this about the squarial? I know i was talking about the dish you have Ross but maybe i'm in the middle of squarial talk ![]() ![]() Edit: yep, just re-read and Rd100 was talking about the squarial, serves me right for reading quickly, but just to clarify i was talking about the dish and LNB you have in your pic. Last edited by ShaunSat; 28-03-2006 at 11:10 PM | |||
| | #17 | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | I was referring to the squarial as having a non changeable lnb. The lnb on the minidish should be changeable with a bit of gentle persuasion, although it will need a lnb with a 20mm collar clamp, and Im a bit concerned about snapping the lnb holder - its only cheap plastic and doesnt look very strong. I might have to make something using slotted strips instead. | ||
| | #18 | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Ok, sorry to drag it up, but I just got me a Squarial too (I started a thread in Retro Tech about it).... I took mine apart and the LNB (or LNC as it says on the label) is removable, but the mount and shape of the hole is totally different to any other LNB I've seen (although all I have seen are 40mm clamps and a C120 fitted to my Attisat). I am thinking of modifying the LNB by removing the old gubbins and replacing it with a modern Sharp Universal minidish LNB PCB, but I'm not 100% sure whether it would work or not... And then there's the fact that I need a new soldering iron as my old one went BANG!!! Anyway, back to the LNB, looking into the hole where the signal is picked up, the little twig looks just like the one in my Attisat's C120 LNB, sooo if I managed to get hold of a C120 (or replace the one in my attisat and use the one taken out of it) I might be able to have a fiddle about and see if that works instead, dunno how I'd attatch it though cos as I said the mount is totally unique to the Squarial... My fingers ache now!!!
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| | #19 | ||
| Regular Member Join Date: 02-12-2005 Location: str8 frum da wesside innit?
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s... | good job 2cv, b shure to brief us as you further advance | ||
| | #20 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Is the little round brown thing the LO? If so, do it need the screw ontop of it??? (I only ask cos the casing of the sharp LNB is long gone and the two (I think) LO's have no screws on them)
| | #21 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Oh, nearly forgot, here's my little former DMAC beauty... ![]() (yes, I took it while I was in bed...)
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() Last edited by 2cvbloke; 13-04-2006 at 05:13 PM | ||
| | #22 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Details off the back of the "LNC": Model: PAC301 Freq. 11, 77-12, 11Ghz Power: DC20V Ser. No. 0122582 So, it's an 11Ghz LNB then???
| | #24 | |||
And yep, I'm an eBayaholic, spend too much time and money on it...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| | #25 | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | A nice surprise with the BSB minidish yesterday evening. was waving it around seeing what I could find and picked up reasonable strength signals from Hungarian service M2 on Hotbird 3. Not perfect but watchable. When Ive got a few minutes I will be trying for some digital signals off the high power Hotbird 7A. | ||
