LX2000 Pipe Antenna | |
| Member Join Date: 18-08-2003
| Can the LX2000 Pipe Antenna be used with an analogue system? Can`t use my 80cm dish as i already have a sky dish up and iam not allowed 2 dishes up without planning permision. Thanks for any help. | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you are looking to receive Astra19.2 Analogue, why not use your 80cm with a second LNB for that and 28.2, no need to spend £150 to achieve what you want Pippin31
__________________ | |||
| The idea behind a pipe antenna is steeped in technobabble. The reality is usually not as good as the adverts claim Get a full test in all weathers first
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #4 | |||
| Specialist Contributor Join Date: 01-01-2000 Location: pj::
My System: Dreambox 7000S + motorised 80cm dish, Amstrad DRX550 Digibox + fixed dish |
__________________ pc:: | |||
Similar Threads | ||||
| Motorized 1,25m antenna | samukas | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 14-06-2006 07:04 PM |
| Toroidal Satellite antenna | erndawg2001 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 7 | 14-02-2006 04:04 PM |
| Satellite Dishes | T24 | FAQs & Glossaries | 1 | 20-08-2004 05:36 AM |
| Antenna Feed switches: 12V & Diseqc | jeallen01 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 16-02-2004 11:56 AM |
| Any experience of the Squarial Flat Plate Antenna? | Dallas | The Meeting Place | 5 | 03-05-2002 11:49 AM |
