Really need help setting up a channel/frequencies. | |
| Regular Member Join Date: 15-09-2006 Location: Sweden
My System: Zehnder DR600 digital receiver, 90cm Amstrad dish and one MTI Blue Line 0,2db LNB. |
Hello, I have an Luxor XTM 980 analogue satellite reciever/decoder. The analogue system hasn't been used for about five yeards but now I want to start using it to tune radio stations. I've tried several times with different radio stations but I can't get it working. When we stopped using it it had been recieving signals from Astra 1 and no one have changed anything since then. This is the station I want to be able to tune on my analogue receiver: Satelliten - Astra 1aThis is what I changed and what was alread entered in the settings: First of all I (obviously ) clicked on "menu" on the remote control. There there was two settings I could change: AFC: Till (To in english I think)and then I clicked on "program settings" or "channel settings" and I filled in the following information: Sat: Astra 19EThat was the current settings, here is the options I could choose from: Main menu settings:I really need help with this because I don't really know what all those settings mean and I've tried to find out but I just found an explanation to a few of them so please, read trough it and see if you can find any errors/wrong settings. Thanks in advance, Best Regards Oskar R | ||
My System: Zehnder DR600 digital receiver, 90cm Amstrad dish and one MTI Blue Line 0,2db LNB. | Hello again, One more thing, I have changed the receiver because mine didn't work so I've never used the receiver with my LNB. Cdan it be something with that? Maybe I need to change some settings? Is there any other settings you can think of that I might need to change? By the way, was my settings described in the first post correct? Best Regard Oskar R | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Can we presume that you are still able to receive the normal analogue video channels? If you are using a universal LNB, you need to make sure that the receiver is setup for a universal LNB, Local oscillator settings 9750 and 10600.
__________________ | |||
