French Channels on 5W in Dublin
Thread Tools Display Modes
Old 18-12-2003   #1
Angry French Channels on 5W in Dublin
I had a guy install a Strong SRT4475 with an 80cm Channel Master dish and a Triax (300431) Universal LNB 10.7-12.75GHz. He could get nothing at 5W. He moved it to Hotbird and using the Digital input you can get any number of digital stations, but switching to Analog and moving the coax to the analog input, you get nothing. Any suggestions?
lrainsbe is offline   Reply With Quote
Old 18-12-2003   #2
Mod and septic resident
Channel Hopper's Avatar
Not sure of the specifications of the 4475, but if its the same design as the 4375 the power and switching protocol for the LNB comes from the digital tuner. You must have a loopthrough lead fitted for it to work, simply moving the lead across from one tuner to another wont work
__________________
Old 18-12-2003   #3
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
The Echostar 3000 uses the same principle.
__________________
Jimbo
jimbo is offline   Reply With Quote
Old 18-12-2003   #4
I have tried the connection both ways. ie Directly to the Analog input and via the Digital input with the jumper cable. Niether seems to work. The manual indicates both methods should work.
Old 18-12-2003   #5
Where did you buy it from
What are the specifications ?
Any picture of the rear panel ?
__________________
Old 18-12-2003   #6
Instacom http://www.instacom.ie/ who sourced it in the UK somewhere
http://www.strongsat.com/products/sp...?p=106&lang=en
Any picture I can find is incorrect. In terms of coax it has Analog IF Input, Analog Loop In, Digital IF Input Digital Loop Out
Old 18-12-2003   #7
Your dealer should ideally have exeprience of these items if they are on their shelves
Do they have a man with a van that can come and check the system ? their guarantee (covered in their profit) should include at the very least one callout
__________________
Old 19-12-2003   #8
The installation company sent the man in the van with a brain last night and it was working within 10 minutes. Many thanks for your help!
Old 11-01-2004   #9
garethlpool
Posts: n/a
Not sure if this is still useful, but by a serious of strokes of luck I get analogue French TV in colour here in Liverpool in virtually perfect reception with a 57cm Arcon Multi dish and a nokia 1700SAT receiver bought off Ebay before Christmas. The TV I got is a Grundig Ghia which just switched automatically into Secam operation without any adjustments at all. France 2 is the best pic, also good are France 5 , M6, Canal+, and TF1 is farily ok apart from a few sparklies. The signal is really strong. For some reason can't tune FR3 which is right at the top of the band on 12730MHz somewhere. It's not the universal lnb on the dish stopping reception. Must be the Nokia receiver which has some upper limit. Would like to hear from anyone else using analogue on Atlantic Bird 5 deg west. The prob Ihave now is that it's virtually impossible to record stuff as there's onyl one VCR which likes Secam input around at moment - Samsung 3000W and its £350. So there's the drawback. But at least it's not an annual sub to TPS or Canal Satellite!
Old 21-04-2004   #10
French TV - how much longer?
Hi
Completely new to this - just registered 2 minutes ago. My big old dish has been bashed up by the builders but was working fine for French channels on 5 degrees W. Had this system running since about 1991/2.
Question - is it worth me getting a new dish - ie. how much longer can these analogue satellites keep broadcasting? Does anyone have any idea at all?
Also (getting my money's worth here I know) ... - is there any way of getting FTA French channels (TF1 France 2 France 3 M6 Arte) on digital and how do you do it?
Cheers for any help hints or expertise
Antergi
antergi is offline   Reply With Quote
Old 21-04-2004   #11
Rob
Super Nutty Mod
Rob's Avatar
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Hi Antergi, checkout this website, www.lyngsat.com
Click on Free TV, and then click on France.
It then shows you all the free channels from France, and what satellites they are on etc,etc.
__________________
If anyone wishes to copy the Madeleine appeal please feel free to do so.
Rob is offline   Reply With Quote
Old 07-05-2004   #12
Looks like you got it going, but in case anyone else is wondering -
Coax goes into Digital IF Input. The loop-thru cable should connect Digital Loop Out -> Analog Loop In.
apogee2010 is offline   Reply With Quote
Forum Jump
Similar Threads
English Audio on satellite channels cowboy Transponders & channels 11 23-02-2006 01:08 AM
Digital satellite viewers lose free channels net1 B Sky B Digital and 28.2 East General 5 16-06-2005 01:22 PM
foreign channels smac Digital systems 10 24-10-2003 12:35 AM
Transponder update 20/08/03 Satdude Transponders & channels 0 20-08-2003 04:30 PM
Erotica channels launch. net1 Adult satellite channels 0 24-06-2003 07:38 PM
