Home set up - Help!Audio Visual equipment support forum, from the latest Plasma screens to the best home cinema or surround sound systems. From VHS to DVD+R, from WebTV to HDTV. | |
| Member Join Date: 12-02-2008 Location: Essex, England
My System: Hanspree HD.TV + Wharfdale DVD recorder + Digihome PVR + Virgin media + Phillips home cinema | ![]() Hi, I have an HD TV with 2 x HDMI, 2 Scarts, 1 x S-Video, 1 x component video. I want to connect to it the following:- PVR 2 x scart(with freeview), + DVD-recorder 2 x scart 1 x HDMI, Home Cinema system 1 x scart, Virgin Media box(telewest) 2 x Scart. Everything was working, but, I have done something; and cannot work out what! I used to be able to record on the dvd from the virgin box but no longer can. Any help with configuring this system would be fantastic. Cheers. | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | I find it's best to do a quick drawing of all your boxes and the TV and then add the cables to the drawing depending on what you want to do. | ||
| | #3 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
Check the cable connection between the DVD recorder and the Virgin box and note it's AV name or number. On the DVD, select the AV number corresponding to this connection and on the TV select the appropriate AV number or name that the DVD out cable connects to the TV. Hope that this helps. | |||
| home, set |
