Hi Def or not Hi Def?
Audio Visual equipment support forum, from the latest Plasma screens to the best home cinema or surround sound systems. From VHS to DVD+R, from WebTV to HDTV.
Old 18-10-2008   #1
Member of the Big Dish Club
Robbiewright's Avatar
My System: Sky plus V3 and a 50 inch plasma screen.
A question,, I just got my self a Play Station 3, It can play BluRay DVD's. The cable supplied has a Hi Def connector at one end and RCA plugs at the other. Am I seeing Hi Def on the screen or do I need to get a cable with Hi Def plugs at both ends?
++If it's worth doing, it's worth over doing.++
Robbiewright is offline   Reply With Quote
Old 18-10-2008   #2
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
You need to use an HDMI cable for hi-def.
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
The Following User Says Thank You to mhku For This Useful Post:
Robbiewright (18-10-2008)
def
