Screen cleaning? | |
| Super Moderator Join Date: 24-09-2004 Location: Rochdale
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive |
I have a Toshiba Back projection 42" TV and the screen was getting dusty after some building work.... i cleaned it with soapy water and a cloth, but its gone streaky ![]() i dont want to try anything too strong in case it damages the screen (only plastic) as anyone will know who owns one, the screen is full of little grooves that make cleaning a pain in the backside. any tips guys?
__________________ "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | I use this - but it's not safe for work! Just move your cursor round the screen (requires shockwave plug-in) http://mirrored.flabber.nl/boob.cursor/ciagnijcycka.swf Seriously what you have done so far is what I would have used. Unfortunately it's just a very long job of cleaning and drying an area at a time. If you concentrate on an area about 600mm square - spend some time on it - check it and you'll see the difference. Well worth it in the end - wouldn't use anything but mild soap and water and a clean cloth to dry it. Nothing with heat as that could effect the plastic! | ||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Next time try a soft bristle 2" paintbrush to flick the dust out of the grooves. Ive used iso-propanol quite safely to clean plastics at work, but you would need to test a tiny area first "just in case" | ||
| Regular Member Join Date: 19-12-2005 Location: Derbyshire, England
My System: comag sl65 (x3) Sad but I like them :-) comag porty II (camping) Pace Prima (analogue) Assortment of dishes. computer: Shiney new Acer | Those cheapo ant static "magic dusters" are pretty good for jobs like this. Usually available from the pound shops. | ||
| | #5 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | the thing im worried about most is a problem my then 3 year old had with it... while the wife was cleaning the windows with the mr muscle spray... he picked it up and sprayed the screen (quite a lot) and after running down to the bottom of the screen, it then crept up the back!!! you see its actually 2 sheets of plastic, and the GREEN mr muscle went slowly up the inside!! after a day or 2 it had gone about halfway up.... and dried!! not good. Luckily it was still under the Comet warrenty, which was good because the same 3 year old then hit the screen with a plastic teddy, and put a crack in the screen lol comet replaced the screen free of charge, but the guy that came out told me the screen should have cost £300 OMG!!! so now im being careful
| | #6 | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Keep the 3 year old locked up? | ||
| | #7 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | hes 5 now.... and he knows the full meaning of "You do that and ill beat you half to death!!" so hes better behaved now
| | #8 | ||
| If you have had building work, there is a good chance the dust has also got into the internals, and coated both the three gun lenses, and the primary mirror. Everything will need cleaning, without this, both focussing and brilliance will be affected. Use a compressor to get rid of as much dust from the glass parts, and then opticians cloths, only use liquid is there is residue that cannot be moved as there may be coatings applied at the factory.
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #9 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | only problem there CH, is the warranty... if i open up the TV, to clean the insides. i might compremise the warranty? i agree with what your saying though....dust gets everywhere
Similar Threads | ||||
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| screen cleaning | Analoguesat | Wavey's Jokes Corner (May contain nuts) | 1 | 19-01-2005 08:36 PM |
| Screen cleaning utility | T_G | The Meeting Place | 4 | 14-06-2004 02:08 AM |
| Screen legend dies | net1 | The Meeting Place | 0 | 01-09-2003 09:56 AM |
| Sky News bring back on screen ticker | net1 | B Sky B Digital and 28.2 East General | 0 | 13-08-2003 08:26 PM |
