Are my DVDs beyond repair? | |
| Specialist Contributor Join Date: 11-07-2006 Location: North Tyneside
My System: Motorised dish, dvd players and recorders; a freeview box, broadband, VCRs, four TVs, mobiles, pcs, a mac, Ipod, digital cameras...the lot! |
Hi, chums, I'd like to know something. Most people do on these forums, anyway! ![]() Anyway, I have around 70 DVDs which I have recorded over the last three years. In that time, I've watched them that much, the majority skip "frames" or freeze completely; and the others won't play at all. There are a few still working, but I am interested to know whether the damaged ones are beyond repair, or that there is some fluid I could buy and wipe on the discs to bring the DVDs back to full use again. The scratches aren't deep, not like I went over them with a chizel, they're more surface, light scratches through them being handled and played over the years. Does a scratch, no matter how apparently covering a small surface level, remove the data on the discs? Thanks. Once again, any help appreciated... | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
It may not necessarily be the discs themselves, have you ever cleaned the laser lens on your CDRom?, the build up of of dust on the lens often is the culprit. Just a word of caution use a CDRom cleaning kit, never open a unit and clean it as the laser has the potential to damage your eyesight
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back Last edited by Topper; 23-07-2006 at 10:24 PM | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | You can get the discs 'polished' at some DVD rental outlets. They cannot repair damage to the read surface. Best way to tell is hold the disk up to the light - if you can see the light through the scratches then they are beyond repair. If they have surface scratches on the read side then a polish should work. You can buy home polish kits but I am not sure how effective they are. | ||
| | #4 | |||
You have a point there. Some of the discs play okayish in my PC's DVD drive, whereas in my stand alone DVD players, they' won't work at all. I think the lasers in the stand alone DVD players therefore could do with a clean. Is this possible? Thanks. | |||
| | #5 | |||
Thanks Gameboy, I'll do that - when it's light in the morning. It's pitch black outside now! | |||
| | #6 | ||
| (``-_-´´)[PT] Join Date: 22-05-2006 Location: Portugal
My System: Ferguson | it might be only a prob with the lense but with the quality of your burned DVDs. Many players get in trouble with DVD+/-R
__________________ -- BUGabundo (``-_-´´) ![]() www BrinKadeiraS.BUGabundo.net | ||
| | #7 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | It could also be that one of your standalone DVD players might not understand either DVD+ or DVD- if you have a mix of + and - discs.
__________________ PaulR As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after. | ||
| | #8 | ||
| Guest Join Date: 29-04-2005 Location: Midlands
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | DVDs can't wear out, but in some writable types the written surface has been known to self destruct after a few years. Tiny scratches don't matter, the laser beam width is wide at disc suface, and only focusses to a point inside the disc. If you're getting problems, it's probably the servo control going wonky, needs adjusting with proper equipment and service manual, just cleaning lens will do little (but no harm). Just possibly the laser's failing, if so it will go completely soon, but that's very unlikely. | ||
| | #9 | ||
My System: Motorised dish, dvd players and recorders; a freeview box, broadband, VCRs, four TVs, mobiles, pcs, a mac, Ipod, digital cameras...the lot! | All these discs are write once, if that helps. | ||
| | #10 | ||
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | Nope, makes no difference whether R OR RW, cos it's your player! The servo keeps the laser correctly tracking the spiral of pits (forming the digital bitstream 1s and 0s). As cd and dvd players age, they can start to "jump", due to this gradually worsening. Since its a complex electormechanical system, it could be either mechanical or electrical components slowly changing, and the remedy is proper workshop realignment, but it will be cheaper to buy a new player. Confirm this by playing your dvds in a different machine, they should be ok! You can try cleaing the lens using one of the kits available (the laser can burn a hole in your eye, make sure player is unplugged !!!!), but I don't think that will help. (added) - sorry, I've just realised that's confusing! Some lens cleaners are a special disc that you insert, in which case the player must be switched on. But, UNDER NO CIRCUMSTANCES open up the player without first unplugging it from mains power (for example, if you use a cotton bud to clean the lens, in which case also remember it's delicate). (added later) On most DVD and CD players, there's a safety interlock, where a drawer slides out or lid flips open, physically disconnecting the laser. However, despite this, NEVER look directly straight down into the laser diode, along its central axis, instead always look across it, with the axis pointing well away from your eyes. If you think the laser is shining in your eyes, then quickly turn your head away (bad eye damage takes a few seconds). Last edited by spiney; 24-07-2006 at 12:28 PM | ||
| | #11 | ||
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | hmmmm, have just read top of this thread again. The DVD side opposite from label - where the laser shines though - is not greatly affected by small surface scratches (as the beam is wide at that point, a design feature of optical media formats). If there's bad scratching on the other side, then this may have removed some of the written information. If some parts of the disc have become transparent, then that's a dead givaway, but damage can still occur without this. Remember, although you might think that the transparent side is fragile, actually it's the label side which is most fragile! | ||
| | #12 | ||
My System: Motorised dish, dvd players and recorders; a freeview box, broadband, VCRs, four TVs, mobiles, pcs, a mac, Ipod, digital cameras...the lot! | Once again, I appreciate your interest and advice. The scratches are not transparent. It could be the player/s - I have more than one, but then again, I've always bought cheap discs... Maybe from now, I should go for quality instead of cost cutting. I'm glad to learn that a disc cannot be damaged entirely - so like you peeps said, it's either the cheapo discs themselves, or the cheapo DVD player. I'll get some DVD disc cleaning solution, and see if that helps. Thanks. | ||
| | #13 | ||
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | Well, try the same disc in different players! Is there always a problem at the same point (suggesting a damaged disc)? Or, do the players behave differently (suggesting servo/laser problems?). Perhaps it's both? If you think the discs are deteriorating, it might be a good idea to copy what you can now, before they get worse. see: http://hometheater.about.com/cs/dvdl.../aadvdrota.htm . http://yukongis.ca/bin/view/Main/CdRot Last edited by spiney; 26-07-2006 at 12:51 PM | ||
| | #14 | ||
| Post Meister Join Date: 31-12-1999 Location: Berlin, Germany.
My System: 2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss | I would smear some dishwasher finish glass sparkly stuff on the disc, work it in with clean fingers and run it under a warm tap. Use a lint-free (normal) bath towel to wipe off the water. Never clean in a rotational way (laser travel) - always from the centre to the edge (perpendicular to laser travel). Tedious but worth it. Pop it into your PC drive, save to your hdd - and burn another copy. This time keep it in a cover and don't faff around with it. Grab at edges with thumb and fingers and use the first finger after the thumb to poke through the middle of the disk. I am always having problems with rental dics and careless users. The washing trick does the job. I also find my PC drive is more rugged than ANY of my standalone players. .
__________________ Have Fun, Moo. | ||
| | #15 | |||
I think it's down to the discs, if you pay bananas, you get monkey-made discs... Thanks. | |||
