LCD TV Questions | |
| Member Join Date: 23-09-2004
| Hi All, Our old 24inch Phillips TV has finally given up the ghost so a replacement has got to be found. We have looked at most of the available LCD 28inc + flat screens in the various big name stores and small independents but we are getting a lot of conflicting infomation and opinions. Our main requirement is for the set to be able to handle movement adequately so that sports broadcasts can be enjoyed without any apparent lag. However, some LCDs are not too great on this and opinion seems divided on whether the current generation of LCDs can match CRT on this aspect. This worry has led us to look at HD CRT sets as a suitable alternative to LCD. However, the Samsung HD CRT doesn't get a particularly good write up either. Has anyone any opinions or recommendations to offer on the best way to go ? Another little worry that has come to light during the search is what happens when you watch a standard screen programme on a widescreen TV ? Is it possible to upscale the picture so it fits the screen without side banding on most sets available as two black side bands would drive us mad ! All the best, Kristian. | ||
| | #2 | |||||
| Folding*home Join Date: 23-02-2006 Location: Madeira
My System: [ Relook 250S ] |
__________________ ![]() When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork." | |||||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dreambox 7000s, Seagate 160Gb HD, 256Mb USB,Sky +. 1 mt Dish, MH 120 HH Motor, G Interstar Twin 0.3 Lnb, Matrix,Opus & Tit 1 & 2,Cas 2 + Add on, Linskys Wireless connected to Dreambox and HP Pavilion Zd 7000. Phew! | Nice reply Prophessor
__________________ Happy Dreaming | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | If you're a gamer then LCD may be better for you. Samsung are good for LCD, Pioneer, Panasonic and Fujistsu make good (if pricey) plasmas. | ||
| | #5 | ||
| The Local Drunkard Join Date: 19-08-2005 Location: Almeria, Spain
My System: 130cm dish 80cm motorised dish Silvercrest SL65 FTA Internet cafe broadband Lots of FTA channels on most satellites aimed at europe and middle east. ![]() | LCD´s are great, but thier main problem is the possibility of burned out pixles... Its the luck of the draw, you either get them, or you dont. I have one on my laptop´s sceen, top left hand corner, good thing it want slap bang in the middle! | ||
| | #6 | |||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
| | #7 | ||
| Regular Member Join Date: 26-09-2005 Location: Tyne Wear
My System: Humax 5400irc 80cm Dish Invacom 0.3 LNB ToH 3.3 5.7. P4 Xp home 3.2 pro. | Hi JG.. As Proph said under 10 mili Sec LCDs are as good as a CRT TV as far as Lag goes. I have a 8ms Sony LCD and never noticed any Lag on Freeview or Humax HDCI2000 boxes. One little tip is...A 28 inch CRT TV has the same size screen dimensions as a 26 inch LCD. 2 inches more screen size for your money with the LCD. If you go for a LCD look to the future when they will transmite 1080p signals over tha Air. So look for a panel with 1920 x 1080 resolution, that the resolution of 1080p (Full HD without scaling). BF... | ||
| | #8 | ||
My System: [ Relook 250S ] | There's always "the rub my pixel technique" or "gently tap my pixel". I wish it was a sexual thing.
| | #9 | ||
| Hi All, Many thanks for the replies. Despite thinking the Phillips was dead, I managed to get it repaired. However, all the info is most valuable as I don't think I will be able to get it fixed again and so a new set will become inevitable at some point. All the best, Kristian | ||
