Problems With LG RH277H DVD RecorderAudio Visual equipment support forum, from the latest Plasma screens to the best home cinema or surround sound systems. From VHS to DVD+R, from WebTV to HDTV. | |
| Dreaming Satellites Join Date: 12-06-2005 Location: Stockton-on-Tees, Cleveland
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, |
I have an LG DVD/HardDrive Recorder Model # RH277H, the problem is, when I record a TV program or something from an old VHS tape onto the Harddrive, everything is great, untill i copy the recording from the Harddrive to a DVD+RW disc, the sound seems to be out of sync (just slightly) what am I doing wrong?? is they anything i need to adjust in the settings?? Also, everytime I unplug the recorder, when I switch it back on, i have to manually set the clock (which is really annoying) Can anyone help?? Cheers, | ||
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, | Still no answers??? There must be someone out there who has/are experiencing the same/simular thing... or even any ideas on what to do | ||
I would suspect that as nobody has answered you that nobody has a similar model or is not experiencing the same problem thus has not got a ready made solution for you. Is there nothing in the configuration and setup menu relating to audio setup? Have you read the manual or indeed contacted the manufacturers, they may have a solution to your problem. | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I suspect Topper is right. I can only offer a possible answer. Whenever an analogue signal is converted to digital there is processing of both the video and sound. The video processing is much more processor intensive and takes longer which inevitably introduces a delay. This can be seen on any live broadcast if you watch closely. It could be that you are recording something which has already been through this process (maybe more than once) and you are finally seeing (hearing) an obvious difference. Regarding your clock problem, sorry no idea except, perhaps, it isn't supposed to automatically update. What does the hanbook say? | ||
| | #5 | ||
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, | I've also got a Philips DVD Recorder that I've had for bout 4 year now, have had no bother with that apart from the odd switching itself to standby mode and sometimes not recognizing the discs/DVDs, possibly due to how long I've had it, hence the reason to buy a new recorder, in the meantime i've been connecting the 2 recorders together to transfer me recordings from the harddrive to a DVD, using the RGB SCART inputs/outputs to ensure no loss of quality... (theres always a way round things, lol) Also will contact LG at some point regarding my problem.. | ||
| dvd, problems, recorder, rh277h |
