Live Scores and Live Feeds plugins by danciDiscussion forum for Azbox linux satellite receivers | |
| Member Join Date: 20-09-2007 Location: local disk
My System: dm 500 s |
Live Feeds v0.99 ============= This Plugins, list for You all feeds and You can go directly to them. So from now You dont need PC to use it to search for Feeds. Live Scores v0.99 ============== Show live results with goals, red and yellow cards. You may upload your picons in /EMU/livescore/picons/. Picons are 70x70 pixels, (transparent) gifs. If club name is Dinamo Zagreb, picon name must be dinamozagreb.gif. By UP/DOWN you walk one match up/down. With left/right you walk one page up/down. With ok you see details, ( ok for exit ) Installation: ========= Extract archive livefeeds.zip and You will see two files ( livefeeds.plugin and plugins.lst ). Copy that Files to USB or simply transfer them by FTP to /tmp folder of Your AzBox HD, and now enter on TV in Plug-ins, press Red Button on Remote controller to add plug-in. If You are using USB select to install it from USB, or if You transfered files to /tmp folder install it from tmp folder. Same installation is for live scores. | ||
| danci, feeds, live, plugins, scores |
