Firmware rev. 0.9.3661
Discussion forum for Azbox linux satellite receivers
Old 3 Weeks Ago   #1
My System: , Fibo Gregorian 1.2mtr, Skystar 2
RELEASE NOTES
# FIXED
- Correct a bug regarding the message for screen capture.
- Correct a bug, do not proceed the progress bar at FTP up/download.
- Correct a bug when it occured the FTP login was failed.
- Correct some bugs of the file manager: Icon images / Multi language
messages
- Correct a bug regarding DVB-T&C TS discriptor.
- Correct the gritch noise bug on the HDMI audio.
- Correct a bug regarding the setup display options.
- Correct the bug regarding LEDs on the front panel (AZBox Premium)
- Correct the alphabetical sorting bug of the favorite channel list
- Correct the bug to remember the last channel.
- Correct the scan SAT bug
- Correct the TV buffering problem.
- Correct the MKV player bug whick is not displayed videos
- Correct the time display problem at MKV player
- Correct a memory leak at the new audio driver
- Correct the audio bug which is occuring when the radio was played long
time
- Correct the video bug which regarding display mode like as pan & scan
display
- Correct a fast forward problem to go forward faster.
- Upgrade the YouTube player
# ADDED
- Add new driver for better A/V performance (under testing)
- Add a function to insert many function keys on the USB keyboard.
- Support multi-audio of TS files.
- Add subtitle ID and audio ID at the individual channel.
- Add a decoder recovery routine for correct the radio distortion bug.
- Add a function to be able to select the Dolby output mode (Line mode / RF
mode)
- Add scripts when called at standby and wakeup
/DISK2/etc/standby.sh
/DISK2/etc/wakeup.sh
- Add new driver for Samsung ATSC tuner.
- Modify the azbox SDK and test application
- Add a radio wallpaper register module
- Add the page up/down function at file manager.
- Add a information bar for ATSC
# IMPROVED
- Modify the main menu position.
- Modify the DEMUX structure to be able to parse several PMTs in the same
time.
- Increase IPTV ability to get several types of streams.
- Modified for EPG
+ EIT pool
+ EIT filters
+ Memory Pool
+ Memory menager etc.
- Modify the EIT parser to add a function regarding ATSC
- Modify the scanning PMT method for using multiple PMT filters.
- Optimization of the DEMUX_INFO structure for using the multiple PMT parser
at movie player.
- Apply the multiple PMT parser at the movie player.
- Optimization the memory of the audio player.
- Support VBR at the MP3 player
- Modify web browser and RSS news cause by change the driver.
- Modify to set subtitle at center
- Modify to display full screen at photo viewer.
- Change some video decoder options to solve the mkv file player problems
- Change some audio decoder options to solve the glitch noise problems
- Change the recording file size to 4GB from 3GB (will be changed next
release to detect the max file size from system)
- Modify the network setting timeout for wifi to 1 minute from 30 seconds.
EDIT: I can't seem to be able to upload the firmware...
I have attached a link to the other forum if you have got an account...
Mods please modify as appropriate
_http://www.satdudez.org/forum/attachment.php?attachmentid=38156&d=1256572934
olisun is offline   Reply With Quote
Old 3 Weeks Ago   #2
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and AZ Elite
Also a new fresh MultiCAS ready to downlod using the box.
dig deep is offline   Reply With Quote
firmware, rev
