FTP problem and Factoring resetDiscussion forum for Azbox linux satellite receivers | |
| Member Join Date: 22-08-2007 Location: .
My System: . |
Hi, When I conect to my azbox premium HD I don't have access to serverals directorys like "/" or "/DISK2", i'm using filezilla, I've access to "/EMU". To try correct with a factory reset but only change my setting.... plugins, satellites, my fav, etc. not deleted. How i resolve this problem and how I make a reset factory with clean everythings. Thx in advance. | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | I don't know your box but are you logging in as an admin? | ||
| Member Join Date: 18-09-2009 Location: UK
My System: azbox hd premium hp pavillion laptop | go to to data reset, delete plugins,delete sats (make sure youve backed up channel list first.,then do factory reset, then have firmware patch on usb and reload formatting the application area 1st,that will get everything back. | ||
| factoring, ftp, problem, reset |
