sky cowboys
Thread Tools Display Modes
Old 27-12-2007   #1
tesy's Avatar
My System: raven 70cm dish for 19.2/28.2 and 13e
sky cowboys
Just been over to my mums to sort out a bl--dy sky instaler . The pig was instaling sky to one of my mums neighbours so insted of putting up a dish he pulls my mums lnb out and replaces it with dual output lnb and feeds it into next doors flat , the first thing my mum knows about it is when the tv goes blank . So she looks out the window only to find this d--k with a cable in his hand , he then disapears next door without a word.
luckly I live close to hand so shot over there and had a few words with him like what the f---k is going on.
His excuse that the council was on his back about too many dishes going up and they were watching him
tesy is offline   Reply With Quote
Old 27-12-2007   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
Get onto Sky customer services and complain about the shoddy practises of their subby installers. He was probably running behind on his installs that day and took the quick route rather than the correct way of doing things to install the extra dish.
As the dish is on your mums property you are quite within your rights to disconnect the second cable!
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 27-12-2007   #3
tesy's Avatar
Angry sky cowboys
Sounds like a good idea , Talk about bl--dy cheek and I have just rememberd he still has my mums(who is 75 by the way) lnb the ba----d a cowboy and a robber
Old 27-12-2007   #4
BonceChops's Avatar
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100
That is unbelievable, the cheeky so and so
BonceChops is offline   Reply With Quote
Old 28-12-2007   #5
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Potentially dangerous I would have thought; there's no guarantee the 2 premises are on the same phase supply
pgh13 is offline   Reply With Quote
Old 28-12-2007   #6
bog standard
moosegoose's Avatar
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2.
could you explain why pgh13 i have shared dihes before with owners consent.with no problems.
moosegoose is offline   Reply With Quote
Old 28-12-2007   #7
rolfw's Avatar
The potential between tw phases is 400+ volts, the LNB feeds in these circumstances should be earth bonded, so that any dangerous voltages go to earth.
All multi user systems in apartment blocks have to be earth bonded for the above reason.
Having said that, many people share LNBs and aerial feeds without bonding and I have never heard of an accident caused by this, it is nonetheless potentially dangerous.
I would disconnect the other feed, he had no right to touch your Mum's dish, it does not belong to Sky.
__________________
Rolf
Donate
Old 28-12-2007   #8
koansrc's Avatar
My System: CM 3.0m @ 28.2 w PACE
I think a lawyer would enjoy sinking his/her teeth into something like this. Trespassing comes to mind alongside theft and who knows what else. Don't forget to get the neighbours on your side too. They are probably also assuming they have their own sky dish and lnb.
As for the admitedly ugly dishes sticking out all over the place, part of the problem is that the installers will always install in the easiest position. There may well be other less obvious positions for a dish.
koansrc is offline   Reply With Quote
Old 28-12-2007   #9
dasteelman's Avatar
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card
it happens quiet regular this practice.
happened a few times in my street
__________________
Nice but Dim
dasteelman is offline   Reply With Quote
Old 03-01-2008   #10
tesy's Avatar
Smile
Have now got sky to disconect my mums neighbours feed from her dish and return her equipment to as it was and next door now have there own dish.
The guys who did the work said that it was a right mess before.
Old 03-01-2008   #11
ASBO Club Team Spokesmen
Yeshi's Avatar
My System: Dm500, TM9100, Pace Sky+ box, 1M Dish. Motect 2100.. 43Inch Plasma, Wii, PS2.
Ive done this on installs , dont see the problem.. bearing in mind i only did it on extreme circumstances... ie no line of sight... but on this occasion the owners rents live 10 doors down... there was no Cable and had 60ft trees in his way.. it was lucky his rents had the end house as they had los... we down however have to drop the cable in the gutter and did my speciality on that.. i call it whipping.. 1 person holds the cable one side and i whip it into the gutter on the other..
That wasnt an ideal install but it had to be done..
__________________
Originally Posted by 2cvbloke
But I do vacuum that patch a lot, it's just the flash that makes it look like 5h1t...
Yeshi is offline   Reply With Quote
Old 03-01-2008   #12
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Tesy
Didn't the neighbours wonder where their dish was going to be sited when the sub arrived??
Like ..... "where's the dish".
__________________
Jimbo
jimbo is offline   Reply With Quote
Old 04-01-2008   #13
v9oly's Avatar
My System: Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams.
The potential is 400v+ between phases when the phases are at 230v, is the lnb voltage is about 50V? Would be interesting to know what the voltage across the two lnbs was (assuming different phases), I'm sure it would still be considered potentially lethal as anything over 50V is.
All the best,
Ollie
v9oly is offline   Reply With Quote
Old 04-01-2008   #14
rolfw's Avatar
It isn't to do with the LNB voltage, but if for some reason full mains voltage is passed up the coax cable due to an equipment fault.
__________________
Rolf
Donate
Old 04-01-2008   #15
v9oly's Avatar
Hi Rolf,
Wouldn't fancy being on the end of that regardless of three or single phase
Regards,
Ollie.
Old 04-01-2008   #16
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Originally Posted by v9oly View Post
Hi Rolf,
Regards,
Ollie.
Yes, One phase does hurt a bit, I 've touched the live wire many a time when I was a kid. ( I used to wire things up. LOL) Two phases however, is rather more dangerous, and it is important that you can't touch both of them at the same time.
Old 04-01-2008   #17
My System: Sky HD and Sky Multiroom
Agreed. I've known this kind of practise to happen in apartment blocks not far from me.
Scott Nelson is offline   Reply With Quote
Old 04-01-2008   #18
My System: technomate, t rex cam, cerebro, fun 6, gold, firecrypt. win xp pro.
Lightbulb
stick lnb's to street signs, there's to many of them. kill 2 birds with 1 stone, those nice round ones? could also try lnb's to speed cameras, make them more usefull.
karat is offline   Reply With Quote
Old 04-01-2008   #19
aba
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
Originally Posted by Yeshi View Post
Ive done this on installs , dont see the problem.. bearing in mind i only did it on extreme circumstances... ie no line of sight... but on this occasion the owners rents live 10 doors down... there was no Cable and had 60ft trees in his way.. it was lucky his rents had the end house as they had los... we down however have to drop the cable in the gutter and did my speciality on that.. i call it whipping.. 1 person holds the cable one side and i whip it into the gutter on the other.. That wasnt an ideal install but it had to be done..
i take it you left the coax in the gutter
all i can say is im glad you dont work for me
ive been fitting satellite dishes for over 25 years and not once have i laid coax in the gutter
aba is offline   Reply With Quote
Old 05-01-2008   #20
koansrc's Avatar
As for the actual thread, my 2 cents worth is this : 1) On large appartment blocks it is obligatory that there is one central aerial for TV and not a bunch of them 2) Dishes sticking out all over the place are ugly. Combining the two points, I think it might actually be a good idea to combine as many TVs onto as few dishes as possible, BUT with the owners consent and with the necessary safety precautions. Also new builds could cater for one single point of distribution of all "common" forms of broadcast with pre-installed wiring.
Cables in gutters ? Gutters that usually have moss and permanent moisture ? I guess it's perfect if you're looking for a quick and dirty solution .. .. .. you could even get entry into the house without drilling by coming up through the drains .. .. ..
Last edited by Robbo; 05-01-2008 at 06:27 PM Reason: new thread made for confessions
Old 05-01-2008   #21
Robbo's Avatar
All off topic confessions posts are now here:-
Dodgy Installer and related confessions
Lets keep all the confessions etc in the new thread.
Robbo
Old 05-01-2008   #22
Mod and septic resident
Channel Hopper's Avatar
In an apartment block, the chances of different phase supplies are miniscule, but even so, it should be checked. Best bet is to wire in the same way as the SMATV/CATV system, and then at least you can claim to have followed the procedures.
As for gutter running, with solid dielectric cable, I can't see any real issues unless the gutter is about to be replaced, or the house has no neat way of running exposed cable round/down it (anyone here tried clipping a neat vertical path down pebble-dashing ?)
Sometimes the only option is to throw a cable over a pitched roof, and I know which one I would prefer.
__________________
[IMG] code is Off
Forum Jump
