Faulty pace boxes??? | |
| Regular Member Join Date: 20-01-2008 Location: Lanzarote
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w |
Can someone help with a slight problem. On my 28.2e satellite I have been using a technomate box with a trex cam and a s*y Ftv card to view channel 4&5 etc, for two years and every 6 weeks or so we have to put it into a mates satellite box to keep the "stay alive signal" working. I have recently purchased a second hand s*y box pace box 1.18.6.. version 9f0402 s*y box from fleebay however it will not pick up channel 4 or 5. Also when we go to channel list there are no channels listed, however we can input the frequencys and get sky news and a few other FTA channels but we can only access these through the other channel menu.??? When we imput the channel 4 and 5 frequencies it will find the channels but when we try to view them it sys there is a problem with your card, message 02.?? Having read the other threads on this forum we have tried to leave it plugged in, tuned into sky news and also reboot the box. When we go to system details it says there is no card. Ive seen others asked others with similar problems ///// SO we brought another box (Pace model no 2.1.28E) (version no 9f0402) which will come on for a couple of seconds and then say no satellite signal being recieved. even on sky news or any other FTA ,However does seem to accept our ftv card. Have i just been lucky and brought 2 faulty boxes of fleebay????or can anyone help~advise ?? thanks | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Could be outdated OS software, what's the OS version number? Also, the box models should be on the bottom or back of the box, something like 2200, 2600, etc...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | thank 4 the quick reply they are both 2500n boxes.. the current one connected ~~~~ operating sys version 1.264fh epg software v ~~~ 3.5.4 thanks | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | does anyone know if this is outdated software and if it is I thought that leaving it pluged in would update this. Cheers | ||
| | #5 | ||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: technomate diseq 1500ci+ ibm thinkpad | have you tried a forced software upgrade:- with stb and tele on press backup button on box (keep button depressed) remove power lead from back of box (if hardwired switch off) return power lead to box (switch on) keep backup button depressed until all lights on front of box illuminate when this happens release button message on tele screen should say:- "downloading latest software do not switch off blah blah blah!!! then retry your box regards dave | ||
| The Following User Says Thank You to 4dbennett For This Useful Post: | mcdet8 (14-02-2008) |
| | #6 | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | tried a forced software upgrade but all apears the same no satellite is being received (36) .. O.S.V reads 1.2s4FH '''' epg version 3.5.4 ... does that mean upgrade was unsuccsessfull?????? will try the same thing on the other box.. | ||
| | #7 | ||
| Specialist Contributor Join Date: 22-06-2005 Location: UK: Kent. Spain: Madrid.
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | I think the answer is in the title of your thread "faulty' They must have been dirt cheap, the Pace 2500 is really old. You have one with a faulty card reader, the second one has a major problem somewhere. Even when they work, the Pace 2500 was the least sensitive sky box Pace ever made. A big problem in Lanazarote. Why didn't you buy a Pace 430n? They can be had for around £30 Much more reliable. | ||
| | #8 | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | okay, we have one box working after a forced update, card working fine on channel 4, 5 etc. The only problem is we have to use them on the other channels list, is there any way round that.????? thanks all 4 the help .... | ||
| | #9 | ||
| Regular Member Join Date: 12-12-2007 Location: essex in the wilds somewhere
My System: sky amstrad and panasonic systems 6 pack setup. two 42cm dishes.just ordered a technomate 6900HD with motorised system one metre dish. also at another address.twin feed static 80 mm dish non digital system. 6 year old dell with server memory 680 of |
no wonder the box was faulty ie second hand. in the end it was no good trying to save money. the sky boxes on Ebay | ||
