Zeetv on Sky | |
| Member Join Date: 06-12-2004
Hi.. i have a problem with zeetv channels on sky, they say no signal or keep crackling...all the other sky channels work fine without any problems. Did anyone experience the same problem, and could anyone give me some ideas on how to sort it out please. Many thanks | ||
| | #2 | |||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | Zee TV UK Package Your profile doesn't show your current system, so you probably need to have a dish pointing to Hot Bird 13E, if you don't have it already. How much does the Sky subscription cost / month? Last edited by HB13DISH; 04-06-2008 at 02:09 PM Reason: Editted 12E to 13E | |||
| | #3 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | 12E ????
__________________ | |||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | The Zee channels on 28E changed frequency recently. They moved to 12607V. Interestingly there are also channels on 12607H, so if your dish isnt set up very well (maybe its moved a little in winter storms) you may be getting cross polarity interference.
| | #5 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, In the UK, the easiest way to get those channels is through Sky. I suspect that there is a problem somewhere with the setup if you are getting picture break-up. I checked Zee Music which is FTA and there doesn't seem to be any problem on that transponder. Incidently I had to rescan as it had changed frequency, but the Sky box should take care of that itself. Things to check: Any cordless phones around, turn 'em off see if it improves. Dish alignment/Obstruction/LNB skew Poor quality/water ingress cable, replace with good quality cable like wf100 for example. LNB gone up the spout, very easy and cheap to replace. Start with the cheapest first. Robbo
| | #6 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | | ||
