85 cm dish | |
| Member Join Date: 09-11-2007 Location: uk
My System: 2 x sky digiboxs 1 bush freesat sd 1 FORTECSTAR rec (not in use) |
Hi I have an 85 cm dish with Freesat only on at the present.I intend to swap my 2 sky digiboxs onto this dish and ditch the small sky dish. My query is,what other sat could I pick up besides the astra ones ?(the dish is fixed).I've seen ads for lnb clamps to hold multiple lnb's but I'm not sure what use they would be. | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | You should be able to pull in 13e, 19e and 28e with a multi LNb bracket
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Check the site sponsors for kit here As an installer, I would personally suggest something like the following: 1 x Multi- bracket for dish 2 x Universal LNb's 1 x Quad LNb for 28e 1 x 4x1 DiSEqC Switch 1 x Receiver with at least DiSEqC 1.1 which is standard now. This will give you all channels form 28e ($ky) plus around 2000+ channels from 13e and 19e. Note this also includes paid channels which require a valid subscription. Good Luck
| | #5 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | I thought the o/p only has a freesat box and 2 digiboxes? surely he would be restricted by the limited SR and FEC of those boxes for multisat work or does the bush unit have full capability?
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #6 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | As I said I recommend a 'Receiver with at least DiSEqC 1.1' for the multi sat reception side of things. Leave the $ky boxes connected directly to the Quad for broadcasts from 28e. Problem solved Topper ![]() ??
