Re-Wiring a sky box into different room ?? | |
| Regular Member Join Date: 30-07-2007 Location: BRISTOL
My System: Technomate 5400 CI + USB, INVERTO Silver Tech Universal Twin LNB 0.2, LIDL satellite dish |
I have a sky box in 1 bedroom but want to move it into another bedroom. How would i go about it ? Should i get sky down to do it ? Or can a general electrician re-wire the box ? Is it just a case of wiring the box round the skurting board and through the walls etc... Thanks | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, there's not much to rewire really. You need a length of decent satellite coax eg wf100, a couple of f-conectors and am f-joiner 'barrel'. You can run the cable how you see fit, then just plug it all back in. Remember to turn off the box when disconnecting.
__________________ | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | You can also cable it directly from the dish to the new room. Either option will work
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
