Amstrad DRX400 problem
Thread Tools Display Modes
Old 13-07-2008   #1
My System: Amstrad DRX400
Hi all, new here, be gentle with me
I have been given an Amstrad DRX400 which has been unused for some time. When I connect it to a (definately) working connection it comes up with a message "no satellite signal is being recieved". Im told this might be an easily fixable problem & NOT a fault...Any ideas? Thanx
tiko789 is offline   Reply With Quote
Old 13-07-2008   #2
rolfw's Avatar
First of all check the connections, make sure they are made properly.
http://www.satellites.co.uk/satellit...91-post14.html
You say it is a working connection, how do you know?
__________________
Rolf
Donate
The Following User Says Thank You to rolfw For This Useful Post:
tiko789 (20-07-2008)
Old 13-07-2008   #3
Hi rolfw, I have a Panasonic receiver working on the connection at the moment. When I swap receivers (yes Im turning box off at the mains before disconnect/connect) & connect the Amstrad thats when I get the message "No Satellite signal"
Old 13-07-2008   #4
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Yes, you may have a fault with the power supply that causes the no sat signal message or could be a connection fault as described.
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
The Following User Says Thank You to satelliteman For This Useful Post:
Old 15-07-2008   #5
My System: 3mtr Offset dish. Practically every Sky box made. Quality AV.
Typical causes of this fault are - failure of one or more capacitors in the PSU or faulty tuner unit ( often caused by people doing up the f connector too tight and snapping the inner core in the tuner unit (as connector on box turns round).
DishDick is offline   Reply With Quote
The Following User Says Thank You to DishDick For This Useful Post:
Old 06-08-2008   #6
My System: Sky-HD
The DRX400 are famous for this fault, rare to find a working one these days.
gunn1e is offline   Reply With Quote
Old 07-08-2008   #7
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
What if its on very old software? Have you tried upgrading it ?
__________________
Zorba is offline   Reply With Quote
Old 08-08-2008   #8
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
Very unlikely but.........
Check that that the default freq has not been changed. Seen it a few times where people change it when trying to add channels.
Press
Services
4
01 Select
2
Should be default to 11778. Use the red button to reset defaults and save.
trigger is offline   Reply With Quote
[IMG] code is Off
Forum Jump
