Multi Room/Dish q | |
| Member Join Date: 14-12-2006 Location: Leicester
My System: bottom of the range!! | Hi Fellas,, apologies if this has been asked (..although I searched first )Current equipment: Standard Sony Sky box with 60cm dish and single LNB. I have a magic eye fitted but am very unhappy with the quality on the 2nd tv. I am also in Leicester. (Hope that's covered all bases!) Basically, my girlfriends parents have just signed up for Sky so we 'introduced' them to get a free Sky+ box. Ideally, I would like a multiroom installation but I would like to have an idea of what I'm talking about before I phone Sky. I'm not sure if they'll install a new dish or just replace the box & LNB. So, would I be able to buy a 2nd card so I am able to have 2 receivers working independently? I've got a feeling that I would have to pay another subscription fee for this though. Am I right in thinking that each card is matched to the receiver so I cannot take the card upstairs if I wanted to watch tv in bed? Is there an idiots guide to a multiswitch on here at all? I'm not sure if one of these would help. Also, if this is too expensive (subscription-wise, not equipment..I don't mind buying equipment) I don't mind having the standard dish pointing elsewhere, although I don't really know about the viewing card situation with this either. Sorry ![]() I am open to any suggestions and my knowledge is very limited so even if it seems so simple to you, I may not have thought about it! Thanks. Mark | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Just phone Sky and tell them you want multiroom, they will supply a second card. You will either need to install a quad LNB to the dish yourself, or get them to do it. You will also need to connect both digiboxes to the phone line. Multiroom is an extra £10 per month.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | vindaloo (22-08-2008) |
