T.V remote
Thread Tools Display Modes
Old 13-08-2002   #1
Member of the Big Dish Club
Robbiewright's Avatar
My System: Sky plus V3 and a 50 inch plasma screen.
T.V remote
I have just moved house and the battery came out of the remote control, now the T.V dosn't work from the sky remote any more. Can some one pleaswtell me how to reset it? Sorry, I lost the book too.
Robbiewright is offline   Reply With Quote
Old 13-08-2002   #2
rolfw's Avatar
What make is it Robbie? I'll grab the code for you.
rolf
PS Have you still got the great view from your new house?
__________________
Rolf
Donate
Old 13-08-2002   #3
T.V is a Grundig. Boy oh boy that was quick.
Old 13-08-2002   #4
rolfw's Avatar
OK, for a grundig its 0345
Press TV
Press Select and TV together until send light blinks twice on RC
Press TV and then type in the code
Press the off button on the remote, if the TV switches off, press select.
If that code doesn't switch off the TV, press TV and then OFF until it does switch off.
This is cycling through the next available codes, so don't do it too quickly.
When you find one that works, press select.
rolf
__________________
Rolf
Donate
Old 13-08-2002   #5
Maybe the R.C is getting a bit old. I have done this before and it worked a treat but now I can get the light to blink. Changed batterys but no change.
Old 13-08-2002   #6
rolfw's Avatar
Hmm, i suppose that its not unknown for remotes to wear out, biggest problem is button contacts wearing out. You may have to be very deliberate with your button presses
As a permanent source of info got to http://www.sathelp.co.uk and press the sky remote codes button, there are all of the setting methods there.
If you PM me Robbie, I can possibly get a new one sent out to you.
rolf
__________________
Rolf
Donate
Old 13-08-2002   #7
Thanks for you help. I have some one coming from London so I will get them to pick me up one and hand carry it out. Posting things to Egypt is more hassel then its worth, customs somtimes want up to 200% of the value if thay don't know what it is. Are all the R.C's the same or dose it depend on what sort of box i have?
Old 13-08-2002   #8
rolfw's Avatar
No they're all the same, there are also some companies doing some really good deals, some for the remote alone and some for the remote and TV link.
Rolf
PS. You didn't say whether you still have the spectacular rooftop view.
Rolf
__________________
Rolf
Donate
Old 13-08-2002   #9
No, I have lost the pyrmids view but I have a far bigger place with a pool and no Mosque next door to wake me up at sun rise every morning. Very nice indeed.
Old 13-08-2002   #10
rolfw's Avatar
Sounds nice, I still think your photo from the roof of your old place with the dish and the pyramids is one of the best I've seen.
rolf
__________________
Rolf
Donate
Old 13-08-2002   #11
w hole's Avatar
Don't want to spoil the party, but they are not all the same.
I bought a Thomson TV, and couldn't get the sky Remote to work it.
I telephoned Thomson and they sent me a new R.C. [for FREE] and it will accept the code for the Thomson TV.
My guess is that some of the older ones didn't have as many codes pre-loaded as the newer ones, so it shouldn't cause a problem if you get a new one.
Regards
W.H.
w hole is offline   Reply With Quote
Old 13-08-2002   #12
rolfw's Avatar
Cheers WH, I suppose that would stand to reason,. So to sum up, its correct to say that if you buy a new one they are, or at least should be all the same, but an old one may not have all the latest codes.
Rolf
__________________
Rolf
Donate
Old 13-08-2002   #13
My T.V is an old one so I don't think it should matter.
Old 13-08-2002   #14
rolfw's Avatar
Just a thought, does the light blink with any codes? Try something like the Panasonic 0081, its one of the most common, so if there are any that work.......
There are also a lot of 3 digit codes on the sathelp site, it may be worth seeing if your control responds to them.
__________________
Rolf
Donate
Old 13-08-2002   #15
nope, dead as a door nail, may be a thump with a hammer will do the trick, no prob's any-how, I can live with 2 R.C's
Old 13-08-2002   #16
It works!! Bit of a typo Rolf. I looked at the link you gave me and it said to press the select and the red button at the same time, not the slect and the T.V button.
Any-how, it works now and thanks so much for you help.
Robbie.
Old 13-08-2002   #17
rolfw's Avatar
These guys in the UK are around the cheapest at the moment at £15 plus £1.99 carriage http://www.brymar.co.uk/
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
Similar Threads
The Ultimate Idiot Guide! For Idiots by Idiots!Answers,Questions,Tips + Tricks: RTFM! T_G Dreambox Guides, Stickies and FAQs 49 2 Weeks Ago 11:35 PM
keys in dreambox pistolpetos Dreambox General 27 21-02-2006 02:32 AM
Bb Aio "Silver card" remote calculator T24 Editors, Utilities and miscellaneous downloads 0 14-10-2003 11:30 PM
Echostar remote control protocol? easysat Digital systems 0 10-10-2003 10:16 AM
Skt remote for TV Robbiewright Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 3 19-08-2003 11:57 AM
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
