This don't make sense | |
| Guest
Posts: n/a
| Hello, this is a strange question but maybe somebody somewhere has an answer. 1. Aligned my dish with satellite meter. 2. Plug in Pace 2500 digibox to lnb and mains. 3. System says "no signal" 4. Turn off 22khz tone - get some channels and quality 5. Turn on 22khz tone - loose some channels but gain some that wern't there when 22 khz was off AND loose all quality ( NOT LOCKED ) 6. Turn off digibox - Put satellete meter between digibox and lnb. 7. Turn on digibox - All channels good and good quality 1/4 signal strength ( which is what is expected ). 8. If I leave power on the digibox and take the meter out, the channels last about 20minutes then go. ( Channel 4 + E4 especially ) Question is, why do I loose channels when the meter IS NOT put inline. I'm happy to leave the meter where it is but if it ever brakes with constant usage then it's back to turning 22khz tone on and off to get different channels and C4, E4, CNBC will never be there. Please help Thanks in advance koonto | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You don't mention what type of dish and LNB you are using, but there are known issues with certain Digiboxes and LNBs. It would be interesting if you could try your digibox on another, known to be working dish and another digibox on your dish. The switching on and off of the 22Khz tone switch could well be a red herring and possibly why the installers menu is not obviously available to the general public, you must also check that the Low and High band LOs are set to 9.75 and10.6 respectively.
__________________ | |||
| It does sound like the L.O may be out on the LNB, however I do know of problems with the 14/18 volt switching on the Pace units unable to give correct switching between polarities on some systems, due to generated higher voltage The signal meter in line may cause a loss of up to 1V of this excess, leading to the correct parameters Try another receiver first before climbing out onto the roof
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| Guest
Posts: n/a
| Cheers for the replies, the lnb is made by grundig and it's mounted on a standard sky dish. The problem is that I'm in a ntl area so all my neighbours don't have sky, so I can't check my box out on another system. NTL Sucks. I've checked all the settings are at default. LO and HIGH band oscillators. If it's not gonna kill my system then I'll keep the meter in the circuit. One day i'd like to steer away from sky and get a digital motorized system. Thanks again koonto | ||
Similar Threads | ||||
| Lazer 2003 FTA 1M- Pols** AU Can You make | krzychumik | Conax, Cryptoworks, Nagravision, NDS and Others | 0 | 09-04-2005 10:28 PM |
| How does AVAGO TV make money? | Millard | The Meeting Place | 2 | 29-01-2004 02:14 PM |
| How to make sure your computer is can handle all attacks for free. | Shahid | Computer Discussion | 0 | 23-08-2003 07:01 PM |
| Most Spaniards make appointments for sex | net1 | The Meeting Place | 0 | 04-07-2003 07:38 PM |
| Cheap calls make '3' sales surge | net1 | Mobile phone/GSM chat | 0 | 23-06-2003 07:27 PM |
