Card problem | |
| Member Join Date: 08-02-2005
Hopefully someone can help as I cannot find my manual for my Panasonic TU DSB30. My Brother in law has just purchesed the same unit so he can watch UK sky programmes in Sweden, however this is the problem. Can I check the unit is working before shipping it to Sweden. When I connect it to my dish and insert my card it comes up with a problem for the card. Does this mean that you can only use one card in one box or is there a way that I can register the card into this box just so I can see it does work? I suspect this is in the manual Will I have to do the same again when I transfer back to my box? Hopefully I have put in the correct forum area thanks | ||
| Super Minty Mod Join Date: 31-12-1999 Location: Fife, Scotland
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections | Any active card should work in any box for non-premium channels (so ITV, Sky1 etc should work) If the box has not been used for a while the software might be old. Under the services > system info menu what version does it show? Can you see the card number on the system details page (again under services)? If you can't then either the software is to old (it can be updated) or the card reader is faulty. | ||
Thanks for the info I know its a stupid question but as I have lost my Manual and its been too many years to remember but how do I get into the software tofind this info. Is there a pdf manual on the site somewhere I am new to teh site so not sure where to look? Thanks | ||
I have connected the box back up again and I forgot to say the box does work on BBC1 etc but as soon as I go to ITV it says there is a problem with the card, I have left the system running on BBC to see if there is a time lag etc. Any help would be appreciated on wher to go next and how I open up the installation system etc. | ||
| | #6 | ||
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections | Thats the latest version of the software. What exacltly is the message you get? Also under services>system details is the card number displayed? | ||
| | #7 | ||
Thanks the message is 'There is a problem with your viewing card etc' when I look in services it does not see the card I tried the forced download but nothing seemed to happen but this may be because its the latest level of software I appreciate the help so far | ||
| | #8 | ||
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections | Does the card still work in your box? If so then it looks like the card reader of the new box is faulty. | ||
| | #10 | ||
| Hmm, now what seems to be the problem? Join Date: 01-01-2000 Location: Torreblanca ,Malaga
| The DSB30 digibox seems to have this fault more than other models,you can make the card thicker as the reader pins may not make full contact with the card surface,but it is often easier to buy another digibox...the DSB30 because of software problems is no longer flavour of the month for use abroad............... | ||
| | #12 | |||
| Regular Member Join Date: 23-05-2003 Location: Benitachell, Alicante, Spain
My System: Famaval 3,1, Sky HD, and Dreambox 7025 (using Disecq for Astra 1, Hotbird & Astra 2) plus other FTA boxes and (Spanish) TDT |
At least, that's the case for this fringe area (the Costa Blanca) where, currently, I can't *give* TU-DSB30s away! | |||
Similar Threads | ||||
| Could it be an Lnb problem? DVB Card related problem | d_lamer2003 | Satellite PC Card Systems & Internet by Satellite | 6 | 26-05-2005 09:42 AM |
| MR 1.04 & NOVA card (IRD2) & Manhattan 3300 | Arkadian | Matrix Reloaded, Revolutions and CAS interface | 20 | 08-05-2004 02:59 AM |
| why wont my elvis programmer recognise my titanium card | tipsygent | Cards & Programmers General | 11 | 07-02-2004 06:48 PM |
| Held to ransom on FTV cards!!! | zansi | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 42 | 07-09-2003 07:41 PM |
