home dvd recorders | |
| Regular Member Join Date: 24-03-2003
at the moment i have sky+. if i record a film and want to convert it dvd i need to capture it on my pc before burning it to dvd. im thinking about buying a dvd recorder to save me the hassle. do any of these dvd recorders interface or communicate with sky plus so i dont need to record it once to sky+ and then again on to dvd or would it be possible to use the dvd recoders own hard drive and then burn it to dvd at a faster speed than real time? cheers | ||
| Specialist Contributor Join Date: 22-06-2005 Location: UK: Kent. Spain: Madrid.
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | A DVD recorder will sit happily with a Sky+ box and record anything sent to it by the scart socket (or RF). Make sure you have a good quality scart cable, not a cheap one. The only exceptions are Sky Box Office channels which have macrovision protection, thus preventing copying. | ||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dreambox 7000s, Seagate 160Gb HD, 256Mb USB,Sky +. 1 mt Dish, MH 120 HH Motor, G Interstar Twin 0.3 Lnb, Matrix,Opus & Tit 1 & 2,Cas 2 + Add on, Linskys Wireless connected to Dreambox and HP Pavilion Zd 7000. Phew! | Its the same as recording to dvd later. Just put scart out into the Input scart on dvd. And tv scart from dvd to TV. You can use the timer function on the dvd for this. Ch should be AV 1 or 2 it depends on how many inputs there is. When recorded you can then copy it to your hd on your computer to edit/ burn again etc.
__________________ Happy Dreaming | ||
| thanks. all this depends on the sky box being left on the channel i want to record? so if i want to record a movie on 301 when im out i would need to make sure the sky is left on 301? am i right? | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes you are.
__________________ | |||
Similar Threads | ||||
| Will A Home Recorded DVD Play in USA ? | dishdoctor | AV Discussion, HDTV, Video, DVD, CD, Plasma, LCD etc. | 10 | 16-09-2005 10:29 PM |
| Are DVD recorders reliable? | Donzo Bonzo | The Meeting Place | 3 | 22-03-2005 05:56 AM |
| Where's Home? | waverider | The Meeting Place | 7 | 06-12-2003 08:47 PM |
| Home Office group calls for chatroom moderation guide | net1 | Computer Discussion | 2 | 03-11-2003 07:37 PM |
| Trojan serves porn off home PCs, | net1 | Computer Discussion | 1 | 14-07-2003 11:44 PM |
