Mesh or Solid Dishes | |
| | #2 | |||
| Specialist Contributor Join Date: 03-04-2003 Location: Kyrenia - NORTH CYPRUS
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD |
How can they be same when mesh dish has so much less reflector surface (because of the holes) than solid dish? Definately solid dish is allways better... Large mesh prime dishes are mainly used for C-Band reception. iceman | |||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Sorry, but I disagree. If the holes in the mesh are smaller than 1/2 a wavelength then the incoming signal will "see" a solid dish. If a solid dish and a mesh dish were made from the same perss there would be no difference in signal gathering efficiency. A mesh dish better on 2 grounds. It is less visually obtrusive (all right - only slightly) and when it is windy it will not put as much strain on the mounting pole and bracket. BTW, this explains why you shouldn't use a C band dish on Ku band. The C band mesh is spaced much wider than for Ku band. As far as the Ku band signals are concerned the dish is practically not there! PaulR | ||
| | #5 | ||
Date: Sun, 10 Oct 1999 15:06:28 +0200 "Rafael P. Sandoval" wrote: For a given frequency in the Ku band, for the reception of TV signals, is a solid dish better than a mesh dish? If so, please explain. Also I know that the "holes" in a mesh could affect the reception of signals in either the C or Ku bands. If this is so, why are there mesh dishes? Thank you and best regards, Dr.Dish: A accurate made mesh-dish delivers in ku-band a signal strength with the factor of 0.8, compared to a accurate made solid dish. This means you can compare a 3m mesh-dish with 2.4m solid dish. Much better is a double-mesh antenna. The holes are small enough to reflect a ku-band signal without too much losses, but still is not very strong to keep always a perfect parabolic shape (wind/change of temperatures). On the other hand, a strong and accurate made mesh dish will survive easier the full load of a storm. The mesh is a relict out of the old c-band age and works fine on this frequency-range. -- Christian Mass (Dr.Dish)™ © 1999 by Dr.Dish copy pasted from http://www.drdish.com/knowledge/9910/991003.shtml iceman | ||
| | #6 | ||
| aka Skyman Join Date: 13-06-2003 Location: Limassol, Sunny Cyprus
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii ![]() | You shold see the big mesh dishes down along the seafront here.The older ones look like skeletons because the wind has ripped of the mesh.Probably get a bit torn from hailstones etc and the strong winds do the rest.and they rust quickly because the frames and struts are all hollow tubing,which is why they are light,which is why they move a lot in strong winds. | ||
| | #7 | ||
| @neil Depends on your location, how much you initially want to pay, what you wish to watch,(and on what frequency), how often you are prepared to pay for servicing / repair/ replacement, and whether the neighbours would notice a 7m mesh thing, or a 5m solid one For me, solid wins every time
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #9 | ||
| Guest
Posts: n/a
| Solid is better. When it snows all the minidishes are covered in snow where as my channel master 1.2m dish is only partly covered in snow and can still get a signal from astra 2 slot. On mesh dishes the snow blocks up the holes in the mesh reducing the signal and hence no picture and since the dish is so small you will lose picture altogether the slightest hint of any bad weather. David | ||
Similar Threads | ||||
| mesh vs solid dishes | Simba27 | Einstein's Alcove | 29 | 12-07-2006 04:54 PM |
| Dish Choice - Mesh or Solid, which is best? | Markie9999 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 04-12-2004 07:42 AM |
| Two dishes over a single cable? | Martie | Multi-receiver/TV systems | 6 | 18-11-2004 07:24 PM |
| Dishes | sailor | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 6 | 30-06-2003 01:12 AM |
| Solid Vs mesh | Robbiewright | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 4 | 23-02-2003 12:14 PM |
