urgent help please in exchange for... | |
| Member Join Date: 08-09-2003
| Pace Digibox locked on standby. A solution to this problem urgently will be rewarded. PPV adult channel accessed briefly with telephone line disconnected. After a few minutes TV then switched to sky sports then switched back to PPV but this time pin number not re-entered. During this time phone line still disconnected. Sky box switched off at mains,phone line reconnected and then box switched on again. Box is now locked on standby. Forced download tried unsuccessfully. High pitched noise comes from back of box. Should an engineer have to come out will they know the hidden menu has been activated or do the "television settings" as well as the other settings return to the original default settings after the box has been switched off at the mains for how long? If an engineer were to find numbers entered thru a hidden menu what is the likely course of action? thanx in anticipation raymond | ||
| Moderator & General Globetrotter Join Date: 01-01-2000 Location: North West UK & Algarve Portugal
| Raymond, What model is the Pace? It sound's like it has developed a fault as the high pitched sound is usually a overload of the power supply.
__________________ zansi | ||
| | #3 | |||
I think it is 2500-S5 although i can't be sure as i do not know where to find the model number. thanx raymond | |||
| Model number on white label on underside of box. Is it BSKYB 2500s5 ? Have you tried disconnecting it off for 1/2 hour then reconnect leave for 3 mins then press the blue sky button to bring out of standby and hope for the best! No common faults known on this model, as relatively new.
| | #5 | |||
the model is in fact 2500n. Whether that makes a difference or not I don't now. I would appreciate your views on whether the sky enineer will be able to "spot" the settings change or does the television settings on the box reset to default settings after a period of time switched off at the mains and if they can be "spotted" what's the likely course of action. raymond | |||
| | #6 | ||
| I would think the Sky "engineer" would not give a damn about the settings, I would be very suprised if he can effect a repair with the fault you describe. It will almost certainly be a back to workshop. Maybe time to upgrade to a newer model or Sky+ at the reduced new price with no monthly fee. Instead of paying the exorbitant £60 call out!
| | #9 | |||
thanx again Zansi I will let you know how things go. P.S. dishdoctor, I didn't use the 123 prefix so thankfully I have no worries on that score. | |||
| | #10 | ||
| Member Join Date: 30-09-2003
| I was using the 1471 trick, until my box decided enough is enough, displaying the msg 'spending limit exceeded - contact s*y' !! After that, I thought ol'well, no-more PPV for me, didn't want to phone them and try and make up some excuse (dodgy phone line or something), anyways, got enough PPV with taquilla, direkt and ticket. Now, the moral of the story was that, I received a statement from S*y (a new thing apparently) not long back, and it detailed ALL the PPV films I had ordered without paying for ?? So, basically the box doesn't really need to be connected to a phone line to order PPV - as they can obtain your purchase details from your card OTA. | ||
| | #11 | ||
| thanx for the feedback. I was not using the 1471 method however the result was the same as I was also billed by sky. Just like you said the card still monitors viewer usage. A costly error as I had to have a replacement box installed. We learn through experience eh! The upside is my sky remote is now compatible with my new tv. all the best raymondd P.S. I would like to make a donation to the board does anyone have the paypal address? | ||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Here it is raymondd we are always very grateful to receive any help, no matter how small and thank you for the thought. ![]() Click Here to donate by Nochex or Paypal, Click Here to donate by Paypal
__________________ | |||
| | #13 | |||
| Long Term Contributor Join Date: 01-01-2000 Location: Sunny old Bristol
My System: Pace Ver.3 SKY+ box 1,20m Dish Quad Invacom 0, 3db LNB P4 3,4 ghz 1024mb RAM Geforce 256mb 6800 Ultra |
Methos. | |||
Similar Threads | ||||
| Exchange rate heaven | Razor | The Meeting Place | 0 | 09-10-2002 10:58 AM |
| URGENT! Which box should I buy? | dockerslund26 | B Sky B Digital and 28.2 East General | 5 | 13-06-2002 05:55 PM |
| MK Exchange Full Clone | Silvercard | Seca/Mediaguard system | 0 | 24-10-2001 11:33 AM |
