Sky Epg 101, 103 In Spain
Thread Tools Display Modes
Old 10-09-2003   #1
I'm looking to set up a FTV system at a house near Murcia airport on Spain's Costa Calida(south Costa Blanca).
I've been told that in southern Spain one can't get ITV1 on 103.....you can only get stuff on vertical polaristaion....and it has to be accessed thru add channels etc...my question is this:
Channel Islands ITV is on V polarisation....and BBC 1 Channel Islands looks like it will go onto V polarisation too.....
So....if one could activate an FTV card in Jersey or Guernsey...then take that card to Spain....101 and 103 would get BBC1 and ITV1 automatically...is my theory right or am I being naive?!!
andyb is offline   Reply With Quote
Old 10-09-2003   #2
well the card is based on the postcode of the house that has the card sent to it, so if you get a card where you know the bbc/itv regions will be vertical then yes that will work ok.
indios_se is offline   Reply With Quote
Old 10-09-2003   #3
wow...cant believe it's that simple.........anyone in the Channel Islands up for doing me a big favour???? lol
Old 10-09-2003   #4
Moderator & General Globetrotter
zansi's Avatar
Should be possible by selecting 958 and using "add channels" for the ITV see below-:
EPG No. Channel Frequency Location
101 BBC One local
102 BBC Two local
941 BBC One Scotland 10.803 Glasgow
942 BBC One Wales 10.803 Cardiff
943 BBC One Northern Ireland 10.773 Belfast
944 BBC One London 10.773 London
945 BBC One North East & Cumbria 10.818 Newcastle
946 BBC One Yorkshire 10.788 Leeds
947 BBC One East Yorkshire & Lincolnshire 10.788 Hull
948 BBC One North West 10.788 Manchester
949 BBC One West Midlands 10.788 Birmingham
950 BBC One East Midlands 10.788 Nottingham
951 BBC One East (East edition) 10.788 Norwich
952 BBC One East (West edition) 10.847 Cambridge
953 BBC One South East 10.818 Tunbridge Wells
954 BBC One South 10.818 Southampton
955 BBC One South (Oxford) 10.818 Oxford
956 BBC One West 10.818 Bristol
957 BBC One South West 10.818 Plymouth
958 BBC One Channel Islands 10.847 Jersey
959 BBC Two England 10.773 London
960 BBC Two Scotland 10.803 Glasgow
961 BBC 2W (BBC Two Wales) 10.803 Cardiff
962 BBC Two Northern Ireland 10.803 Belfast
ITV other regions available by adding channels as per below-:
Manual Tuning
To access the extra channels, you need to add them to the "Other Channels"
section of the Digibox "Services" menu.
Bring up the Services menu and choose option 4 for System Set-up then 4 again
for Add Channels. Type in the frequency as shown in below, together with the
polarity letter either H or V. For Astra transponders 1 to 40 leave the
Symbol rate 22000 and FEC 5/6 at their default values.Choose Find Channels and the
list of channels being broadcast by that transponder appears. Highlight the
name and press the yellow button for all the ones you wish to add to your
list. Pressing the Select button saves your choices; your selected channels
will now be available under the "Other Channels" option in the Services
menu. You can save up to 50 channels in this fashion
ITV Regions-: 10832 H 22000 5/6, 10906 H 22000 5/6,10906 V 22000 5/6
__________________
zansi
zansi is offline   Reply With Quote
Old 10-09-2003   #5
rolfw's Avatar
That would appear to be the only fly in the ointment Andyb, AFAIK they are no longer issuing FTV cards (unless the CI are a special case) and even if you get hold of one that has been issued to a Channel Island address, you will probably no longer be able to activate it.
So you would need to find one that is no longer needed, but has been activated.
__________________
Rolf
Donate
Old 10-09-2003   #6
devonbrown's Avatar
My System: 4 systems. In Scotland Sky with Pace 2600C1. In Costa del Sol 1.3 meter offset with Inv quad 0.3 LNB with pace 2600C1. In Algarve 1.5 fixed Inv Quad LNB with 4 Pace 2600C1 also 80cm dish with Inverto 0.2db monoblock LNB 19.2E/13E and TM_5400C1+ USB
I have a system in the Costa del Sol and I get STV on ch103. STV is on the same frequency as Chan Islands. I do not believe that your first premise that you cannot get BBC! 0n 101 and ITV on 103 in southern Spain is correct
devonbrown is offline   Reply With Quote
Old 10-09-2003   #7
Hmm, now what seems to be the problem?
dishdoctor's Avatar
You can receive all channels in southern spain with a 1.3 dish.You can receive all channels in Murcia with a 1.8 dish,now whats the problem?...brian
dishdoctor is offline   Reply With Quote
Old 11-09-2003   #8
We are in Southern Spain(70k East of Malaga) and receive all BBC channels,ITV,C4,C5 with no problem using a 1.2 metre dish both on the older type viewing card and the new dark blue card. The banner warning about loss of channels hasn't been seen for 2 weeks,and on the dark blue card it was never seen a all.
The only problem we have noticed is that C4 tends to break up a little between 20-2200 most evenings,
Paul
gensavage is offline   Reply With Quote
Old 19-12-2004   #9
I've just picked up a Sky eliptical digi mesh dish that is 70cm across with a Grundig lnb on it. Is there any chance of picking up Sky in Southern Spain (south of Granada) with this??
photomoto is offline   Reply With Quote
Old 19-12-2004   #10
Sky Dish
We live on the coast 70K East of Malaga and use a 1.3 metre dish which is the very minimum for this area,friends have tried a 1.2 metre and they cannot receive C4/5,even with a 1.3 dish we lose it occasionally during low cloud or stormy weather
Old 31-12-2004   #11
dago's Avatar
you'll need a much bigger dish, at least 1.5 to be sure of a decent reception.
regards.
dago is offline   Reply With Quote
Old 31-12-2004   #12
devonbrown's Avatar
I am in Estepona and I get everything with a 1.3 dish, except in heavy rain which doesn´t happen here all that often
Old 18-04-2007   #13
falla-baratto's Avatar
My System: Mvision HD200 Astra 19ºEast and Eurobird 9ºEast
101 BBC One local
102 BBC Two local
Manual Tuning
Tanks for this list.
Where find one list more complete?
falla-baratto is offline   Reply With Quote
Old 18-04-2007   #14
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
http://www.flysat.com/28east.php
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
[IMG] code is Off
Forum Jump
Similar Threads
Sky throws down gauntlet net1 Daily Satellite and Broadcast industry News 11 25-01-2006 03:06 AM
BSkyB commits to free Sky One net1 B Sky B Digital and 28.2 East General 2 09-11-2004 01:14 PM
Sky unveils plans for Plus net1 Sky+ and PVR Systems 0 03-03-2004 08:24 PM
Changes To Sky Movies net1 B Sky B Digital and 28.2 East General 0 20-10-2003 07:00 PM
Will the BBC's satellite dream ever take off? net1 Daily Satellite and Broadcast industry News 0 26-06-2003 08:49 PM
