Sky Channels Disappearing at Night
Thread Tools Display Modes
Old 14-01-2004   #1
I have a sky digital standard installation with all the channels and a Panasonic box. I have been having problems accessing some of the movie channels at night around 7:00 pm. The channels that are not able to be viewed are Sky Movies 1, 2, 3 and 9.
Any ideas
Sophie is offline   Reply With Quote
Old 14-01-2004   #2
Mod and septic resident
Channel Hopper's Avatar
If you had said 1, 2, 3 and 8 the I would have said check the f plug, cable run and maybe the LNB as thay are all transmitting on 11,836
Sky Movies 9 though is a strange one.
__________________
Old 14-01-2004   #3
rolfw's Avatar
Hi Sophie,
Just looked at http://www.lyngsat.com/packages/skyuk.shtml and those channels are found on two different Horizontal High band transponders. It may well be that your dish is lightly out of alignment. You can check the signal strength and quality of those transponders, by going into Services, type in 4, 0, 1, Select (don't worry about what it says on the screen) and go into Manual Tuning.
Type in
11836
and change the following fields to:
H
27500
2/3
You can do the same for any other troublesome transponder.
Will be interested to see what the readings are.
__________________
Rolf
Donate
Old 17-01-2004   #4
Sorry I'm a bit Dim
j.m.'s Avatar
My installation failed that test
Ummmmmmm
j.m. is offline   Reply With Quote
Old 17-01-2004   #5
rolfw's Avatar
Probably the dish needing tweaking then, if it is accessible and you have a long lead for a portable TV, you can do it yourself using that menu, it probably only needs a small amount of movement.
__________________
Rolf
Donate
Old 17-01-2004   #6
Irish Mod
Razor's Avatar
Ummmmmmm
04.10am ....Do you guys ever sleep?
Also screen capture at 04.10am and post at 04.17am ......Not bad, Not bad at all.
__________________
Don't mind my spelling
Razor is offline   Reply With Quote
Old 17-01-2004   #7
Sorry I'm a bit Dim
j.m.'s Avatar
Sleep is for wimps
Old 17-01-2004   #8
Irish Mod
Razor's Avatar
LOL
__________________
Old 17-01-2004   #9
radioscanner's Avatar
Where are you located?
If your outside of the Astra 2D footprint (ie Spain), it is very common to lose many of the channels in the afternoon and evening.
The reason for this is - there is a problem with one of the solar panel mechanisms, the satellite needs to tilt slightly to catch the sun, so the footprint moves slightly too! this problem will only bother you if your on the edge of the footprint or if your dish is not correctly aligned.
John.
radioscanner is offline   Reply With Quote
Old 17-01-2004   #10
Sorry I'm a bit Dim
j.m.'s Avatar
Lancashire
Old 18-01-2004   #11
rolfw's Avatar
Yes, there's a problem with Lancashire, too many pies........the dishes become overweight.
__________________
Rolf
Donate
Old 18-01-2004   #12
Sorry I'm a bit Dim
j.m.'s Avatar
I'm just wondering if its always been off with its pointing....... Or the winds had it ?????
Me thinks its allways been off...... Not bad for a first attempt tho :-)
Old 18-01-2004   #13
rolfw's Avatar
It doesn't take much J.M. only a couple of millimetres in one polarity.
__________________
Rolf
Donate
Old 20-01-2004   #14
Sorry I'm a bit Dim
j.m.'s Avatar
Does this look right to you chaps?
Old 20-01-2004   #15
rolfw's Avatar
Looks about right J.M., but to be quite honest, for smaller dish alignment, it is best to use the suck it and see method. A protable TV on a long lead and just try tipping the edges of the dish, first in the horizontal and then in the vertical plane, you should see a reaction after a secnd or so on the TV screen.
Failing that, you can use one of the very cheap tone meters to rest the dish, they normally do quite a good job.
__________________
Rolf
Donate
Old 20-01-2004   #16
Sorry I'm a bit Dim
j.m.'s Avatar
Problem is......... Its a Loooooooong way up ........ Which is probably why its a bit of a dodgy install........ I have tried to hide the dish just behind the apex of the roof on the gable end ....... Pretty very pretty...... I now understand why Sky installers tend not to be too immaginative when locating these things I'm waiting for a none too windy day & no bloomin rain
Old 20-01-2004   #17
Salty Tech Monster Mod
waverider's Avatar
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+
Any ideas
I had this problem once, including picture lock up's, as I was out of contract Sky wanted to charge me for an engineer to come round! (Bloody cheek!) So I threatened to cancel, their tone soon changed! Sky then offered to send an engineer round for FREE!, which they did.....problem was the LNB, replaced F.O.C.
waverider is offline   Reply With Quote
[IMG] code is Off
Forum Jump
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
Sky News Irish Service net1 B Sky B Digital and 28.2 East General 0 05-10-2003 08:11 PM
SKY: 3 New Channels to Launch soon net1 B Sky B Digital and 28.2 East General 0 12-08-2003 08:22 PM
Will the BBC's satellite dream ever take off? net1 Daily Satellite and Broadcast industry News 0 26-06-2003 08:49 PM
SKY: 11 new channels from Richard Desmond net1 B Sky B Digital and 28.2 East General 3 25-06-2003 10:02 PM
