Sky HD on my motorised dish. | |
| Member Join Date: 16-09-2007 Location: Wirral
My System: DM 500s. 95cm dish 0.1 best LNB Dark motor 1.3 |
Do you need a new "special" LNB to pick up HD chans? I am thinking of getting a thomson HD box but am worried that it wont work with my 95cm motorised dish and Best 0.1 LNB. Your thoughts are appreciated. ta | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No special LNB required, a universal LNB is fine, apart from you will need two feeds, so it will have to be a quad. ![]() The Sky HD box will of course not move the motor, you would probably be better putting up minidish for Sky.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | chavo (22-09-2007) |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | yeah i'd advise using a separate mini dish for sky, as it saves a lot of hassle as sky boxes tend to throw a wobbler if they aren't on astra 2, 28east | ||
My System: DM 500s. 95cm dish 0.1 best LNB Dark motor 1.3 | right thanks very for the advice. Would it be able to record etc? i dont have a land line in my house and sky told me that it wouldnt work. The quad thing you speak of, is that a LNB or is it a box? could someone post a link to go good one so i can price them up. Thanks as always | ||
| | #5 | |||
| Broadcast / RF engineer Join Date: 20-02-2006 Location: SE Wales UK
My System: 3.7m & 1.8m Prodelin, 1.2m Andrew, Loads of receivers, Orbit & showtime & AFN. | To get the card active for HD you need to do a call back You can buy a mini dish and quad off Ebay
