sky HD | |
| Part Timer Join Date: 05-10-2005 Location: that would be telling
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | have just upgraded to sky HD, i have had a full package for ten years plus and it has been in my 7025 for 2 years now. the question i need to know if anyone can help is do i need to put my sky card in a sky HD box to update it to work. can not see for myself as cccam is not working with sly uk card yet.
__________________ If it is not broke fix it till it is | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | As far as I know, the card will not provide the HD channels, until it has been paired to an HD box.
__________________ | |||
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | do you think it would update with any HD box wolf and would i need the box number or card number to add to the cfg file. cheers.
