Sky HD and a Dragon CAM
Thread Tools Display Modes
Old 23-07-2007   #26
My System: SKY HD, 32" Samsung LCD HDTV, XP 4200 Dual Core, 4GB Memory, 1.5TB SATA300, some in raid some not. ATI 256MB X1950pro, Vista Ultimate. TTs3200 + Budget CI and Starkey!
i got the card setup using TT-Media Centre, all the FTA stuff working SD and HD. now i have a CI card that came with the tt-s3200 but it didnt come with the cable to conenct them both together, is it just a standard ide cable or a special cable?
now i heard some more that i dont need a cam and can use software cams or something?
i couldnt get anything going with dvb viewer not sure why, gonan have another mess around with it.
but the tt-media centre works fine and records ok aswell to a ts file. just need to get my hd subs working on it now
pattaya is offline   Reply With Quote
Old 06-08-2007   #27
My System: DualCore Intel Core 2 Duo E6600, Asus P5W DH Deluxe, 2048 MB RAM (DDR2-667 DDR2 SDRAM), NVIDIA GeForce 7300 GT (512 MB), TT-budget S2-3200, T-Rex Super 4.6
I just got a S2-3200 with a T-Rex CAM last week and have just set it up to receive s*y. Sure you`ll need a CAM if you want to watch s*y as you have to put the s*y card in the CAM to watch s*y on your pc, although im no expert on this, im sure someone here will confirm that. You`ll also need a cas interface to load the firmware into the CAM. Ive only just got into this as well, you`ll need to do a bit of reading up but its fairly easy to do once you know what your doing!
cheers,
Lee
J666RST is offline   Reply With Quote
Old 10-11-2007   #28
wxo
My System: Nothing that works
Well there are a lot of things that flat dont work with Vista 64. One of them being media center integration. I settled on DVB viewer which is an excellent product even with the $20 pricetag. I also have a TT 3200 with CAM and CI. No issues with DVBviewer which is more than I can say with some other products. It works nicely with the MCE remote and reciever even in Vista 64 with the appropriate plugin available during install. The remote that came with the 3200 won't work with vista 64 as of yet
I am planning a move to Sky with the same setup so any info on the CAM that you wind up with would be helpful.
wxo is offline   Reply With Quote
Old 03-02-2008   #29
misterminibus's Avatar
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought.
Can someone please point me in the direction of a "how to" for getting my sly card to work in the dragon is it the sly seriel number I enter or a code on the sly box?
__________________
Tis better to be thought a fool and remain silent than to open one's mouth and remove all doubt.
misterminibus is offline   Reply With Quote
Old 03-02-2008   #30
For the basic package, and FTV channels, you do not need to do anything, apart from insert your subscription card chip facing upwards, and tune in the channels on your receiver.
For the premium channels you need to enter the serial number of the original s*y box the card is paired to.
You also require loading a predator file containing the S*y CAID, which most do.
__________________
Mickha is online now   Reply With Quote
Old 03-02-2008   #31
so just for ch4 ch5 sly3 5life & 5us it doesn't need it?
__________________
Old 04-02-2008   #32
Seany463's Avatar
My System: TechnoTrend S2-3200 & Budget CI, T-Rex Dragon CAM 4.1, Sky Sports plus Entertainment package.
It shouldnt need it for that, my CAM didnt even need the serial of the box for S*y One. Premium channels are things like, sports, movies & adult... etc, I believe
Seany463 is offline   Reply With Quote
Old 04-02-2008   #33
That makes it easy thanks guys
__________________
Old 04-02-2008   #34
My System: Dreambox 7000
Question
Originally Posted by Leee View Post
A Sky card can work in a Dragon CAM, yes.
The question is - keep-alives....IMO they don't work. So after x weeks, the card dies and has to go back into *something* to bring it back to live - that something is a Sky box or a Dreambox running newcamd emu.
how does the activation with a dreambox work? Can anyone confirm that i can activate a s*y hd card via dreambox?
xxxomxxx is offline   Reply With Quote
Old 26-02-2008   #35
My System: Dreambox 7020S Looking to buy a CAM
I would be interested in this info as well. Can anyone speak of the relative merits of the DragonCAM vs any other like T-Rex? Are they essentially comparable?
MichelLeipzig is offline   Reply With Quote
Forum Jump
