Where can i get a cband offset conical scalar ringDiscussion of C-Band reception for Europe and beyond | |
| Regular Member Join Date: 05-03-2009 Location: UK
My System: -------------- |
I am going to have a go at cband and need a offset conical scalar ring is there any seller in the uk or europe of the scalar ring | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! you mean a normal scalar ring,where you put your lnb in? or you buy a new lnb,then usaly this scalarring is included! i have one here,if you want,i can send to you! | ||
My System: -------------- | Hi i have a prime focus scalar ring that came with the lnb but need a offset one to use on a offset dish if you see this site you can see the offset scalar ring _http://www.wsidigital.com/conical-scalar-ring-for-offset-dish.htm is this the type you have. Thanks | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello Antenna 1! yes,i have that item you looking for,complete with exotic cband lnb from rusia! only the weather protection plate in front is missing but you dont need this! the cone in front off,give you better signal performance,but only on ofset antennas! not working on pfa! i dont use ofsetantennas,only pfa! this item is very rar,you dont find in europe,in german its called"trichterrillenfeedhorn"! | ||
| | #5 | ||
| Regular Member Join Date: 20-09-2008 Location: Chicago
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | This works better then the consumer rings. Cost < $5 | ||
| I am not a complete idiot, some parts are missing. | |||
| | #6 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | HellO! Satcom! where i can purchase this ? how much is the diffrence? | ||
| | #7 | ||
| Regular Member Join Date: 08-06-2009 Location: QTH: 47°55′43″N 23°53′33″E
My System: C BANDIT | I tested 49E on my 125c offset dish, in C band of course.My Qth has an advantage getting this bird.The power tp is TV Komi all other are lowes , and sure you not get TV2Denmark which has 7/8 fec offset dishes are not so good for C band receptions unless you are in a good coverage | ||
| | #8 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | what was the bigest offset dish ever procuced? to use this cone? to geht optimeized performance i only find mabo form poland with 1,86 m, how,someone,can technicly explained,why this only work on ofset,but not on prime focus dishes? | ||
| | #9 | |||
My System: -------------- | Hi this is what i am looking for i sent you a pm did you get it thanks.
| | #10 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! i just replyed!by mail! sorry my inbox was full,i dont receive the 2.massage you sent! | ||
| | #11 | |||
| Largest one I know (and have worked with) is a 3.8m (four piece configuration). Feeds are designed around the antenna design. A prime focus feed requires signals from what is effectively a deep dish, (up to 0.3 or 0.35 f/d) and so the scalar system is more efficient using a set of rings on a planar surface. With an offset dish (where the focal point is identical, but the antenna reflector is a fraction of the original template of the prime focus design) the needs of the feed are not only to receive the signals, but to reject the outside noise. In this case a horn becomes a better collector of signal. Please note the above is for microwave signals, once the frequency needs drop to below C Band, the yagi becomes a suitable candidate for efficient reception. On, and above Ku band frequencies, other direct means of receptor can be as good as a set of scalar rings. | |||
| There is a very fine line between "hobby" and "mental illness" | ||||
| | #12 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | You can't purchase this you can make it or have someone make it for you. I use springy roof flashing. Others go to their local printer and get flat aluminum sheets that are otherwise thrown away. Typical is 6% SQ gain. Photo courtesy of Walrus1957 | ||
| | #13 | ||
My System: -------------- | Thanks i am going to try and make one just need to find some flat ali metal sheets . | ||
| | #14 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hi! we need exact shematic,and details of the size to make a clone of this!,otherwise,it looks like a imposible mission,that bring not the results we looking for! | ||
| | #15 | ||
| Bit small that Here's the real thing _http://www.aoc.nrao.edu/evla/geninfo/memoseries/evlamemo95.pdf and how to make one from scratch _http://books.google.co.uk/books?id=ZZw7MHFuqF8C&pg=PA300&lpg=PA300&dq=Ring-Loaded+Corrugated+Waveguide&source=bl&ots=8UuizqgP ZH&sig=fGuqFHcYZnZMOCGuNamNX90WzOA&hl=en&ei=f2GiSs zaKpTd-QaevtDkDw&sa=X&oi=book_result&ct=result&resnum=6#v =onepage&q=Ring-Loaded%20Corrugated%20Waveguide&f=false | ||
| The Following User Says Thank You to Channel Hopper For This Useful Post: | Satcom1 (08-10-2009) |
| | #16 | ||
My System: C BANDIT | | ||
| | #17 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hi there! when the size is the same,1,86m lets say,is there a realy big diffrence in cband,between pfa and offset? i never tested this! | ||
| | #18 | ||
| | #19 | ||
My System: -------------- | | ||
| | #20 | ||
My System: C BANDIT | Code: None at all Many manufacturer have deep pfa dishes with 0,36 f/d ratio and there are real garbage 4 exaample my 1,5m pfa dish has f/d=0,42 and performs really fine | ||
| | #21 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello Doctorofsat! and all others!! sure,yes my channel master dish has f/d under 40 if i remember right 34? but how,the this manufactor real measuring,the real gain winning of a dish,in there data sheets? in the past,many companys like gibertini on there ,150m this,and irte ,on my 1,86 m dish,make little design faults,in the lenth of the lnb holder! mostly it was to long,and has to be cutted,to get better performace,like o n the old orbitron sx 12 dish also,all companys,has a ascendancy,but the tech data sheet say no word about it,how the real stated gainwinning in the sheet itsef has been calculated,to get this gain winning value,that you can see on the techpaper! same on lnbs,expect swedish microwave,all other companys,dont put a data sheet in there lnb package! and the dish manufactor,also dont tell us,what eqitment,the have used,that the can say,antenna a wins for example 41 db in kuband and 38 in cband for a 2,40m on the tech sheet of channel master i read about my antenna for expample crosspolarisation on axis minimum 30 db VSWR(Maximum)i dont know what this means 1.3 many things,what we read in the sheets,does not reflect the reality,how the signal realy will be ,because,ther to many ascendancy,other unkown sources! | ||
| | #22 | ||
| | #23 | |||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | In making the Scalar you just trim off the excess overlap not needed for the seam. By now you have likely made your own cone Scalar. But if not it is very easy. I used Super Glue. | |||
| I am not a complete idiot, some parts are missing. Last edited by Satcom1; 08-10-2009 at 04:20 AM. | ||||
| | #24 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | Simple to make all you need is what you see here. | ||
| The Following User Says Thank You to Satcom1 For This Useful Post: | gipras (13-10-2009) |
| | #25 | |||
| Member Join Date: 04-10-2009 Location: italy
My System: clarke tech hh390 gibertini 1m | hi everybody, this week i made this scalar ring with some copper.i tested with my gibertini 1 mt diameter.with original scalar of the lnb panorama,i got nothing from satellites,instead with this original feed i got arabsat and express am1. @satcom1 Can you tell me which satellites you see with your 1mt dish? best regards | |||
| cband, conical, offset, ring, scalar |
