Hello!
i tested,my diablo cam,on may reveivers,on the Manhattan Starlight 5900 ,Zapping Time,goes very long,on germany technisat reveivers,diablo does not work,now i have bought a pace hd reveiver dxb 10xe,now avalible,for 100€
first,the pictures,was full of pixel,sound interruptions,then i half hour later,the reveiver ,reboot ,automaticly,after diablo cam is inserted
i have Rev 2.2,now it would be intresting,are older version works better,then the newer one,on some reveivers?
or maybe,a older,stealth?,does anyone has tested this?
since i have the wirless version,zapping time,are now much longer,then on normal diablo cam,should i remove,this wireless part now?
on Mediamaster 9600 and 9800 it works good,but here,i want to make a list,of receivers,that dont work,maybe we have this,list still here,i dont know,if so,please,add my topic to it,and then we can upgrade,it with more reveivers that dont work,intresting would be,is the reason of incombaitbilty hardware or "softwarebased"?
