Diablo Light Setup
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 25-10-2007   #1
My System: fortec star passion hd
Unhappy Diablo Light Setup
I have just received my Diablo Light and a CAS 3 Plus.
I have Stealth 2.17.
I uploaded the cam with today's key and inserted it to the FORTEC PASSION HD.
Can someone help me find out why I cannot unscramble any programs?
How do I adjust settings on the receiver's menu?
Thanks!
fortechd is offline   Reply With Quote
Old 25-10-2007   #2
shane77's Avatar
My System: sky + TM 1500CI 31.5W - 39E
Have you put the latest keys also?
Let it AU?
shane77 is offline   Reply With Quote
Old 25-10-2007   #3
Got the latest key tonight.
How long is necessary to AU?
Old 25-10-2007   #4
shane77's Avatar
Which channel?
Old 25-10-2007   #5
Rai, Taquilla
Old 25-10-2007   #6
shane77's Avatar
D+ not AU and the keys change 2 or 3 times a night maybe you don't have or haven't been post yet the up to date codes
Old 25-10-2007   #7
I am a newbie at this.
I got the keys from L*urels and simply installed to the Cam through Cas3 plus.
The keys do not specify what it can unscramble. But I cannot open any channels.
Although when I loaded the cam to the receiver, I saw for 3 second a clip from taquilla and then the image paused. This only happens once the cam is re-inserted on the receiver.
Old 25-10-2007   #8
Should I need to input some manual code also. I have noticed that above the downloaded file, there are some lines of long codes (16 sets of 3 codes I think).
I would not have a clue where to key these in to.
Old 25-10-2007   #9
You need to go into the Cams menu and alter the settings:
Enter Configuration menu
Auto PMT ON
Emulators ON
Emulators Priority 1 Emu 2 Cards
Fixed CW OFF
Once this is done Premiere, 19E, and Digi TV, 1W, will AU
Mickha is offline   Reply With Quote
Old 25-10-2007   #10
Hi Mickha,
Thanks for your input.
I am yet to see any channels opened.
The only settings I have changed from the originals (apart yours) is on the CAS section. I have SECA and Nagravision set to [ON] and the rest all [OFF]. I Assumed that these will need to be on.
Is there any other settings I need to change? How long does it needed to be left on a channel for the Auto Update to take place?
Old 25-10-2007   #11
Do not change the CAS settings, this is only required for advanced set up, leave them all on.
Which satellites are you able to view?
If you can get Astra 1 you should have Premiere open, leave it on MGM for 1-2 minutes, or other channel and it will open.
For TPS, on hotbird 13E, you need to leave it on France 4, or other channel on that frequency, for a few minutes, then once opened you can browse the rest of the channels in that package.
The Following User Says Thank You to Mickha For This Useful Post:
fortechd (25-10-2007)
Old 25-10-2007   #12
Thanks Mickha!
After completely switching off and on the receiver from the power button I have all Premier open now! (by following your advise)
I have a monoblock lnb for Astra 13 east and Hotbird 19 east.
When I received the cam, the settings under the CAS menu were all [OFF] and I set SECA and NAGRAVISION [ON] (as mentioned previously)
From what you mentioned above, should I turn all others [ON] also?
Should the RAI and TAQUILLA unscramble without me doing nothing else as at the moment they are scrambled.
Old 25-10-2007   #13
Turn on all the encryption types in CAS.
D+ is no longer AU on the Diablo, or any other system, and requires the keys updating.
I'm not sure if just updating the keys will work with Stealth 217, so you might have to revert back to an earlier Stealth version, but then you will lose Premiere AU, but if you update the keys you will open Premiere.
You should also be able to get Polsat, on Hotbird 13E, only available with Stealth 217, providing you have loaded the correct Diablo keys.bin file.
As previously mentioned you can also open the TPS package, on Hotbird 13E, by leaving your receiver tuned to France 4, and once it clears move to other channels in that package.
Old 25-10-2007   #14
I have put the key for D+ and it opend up the channels (Taquilla) but it only shows the picture for about 1 minute and then it freezes. The only way to see the picture again is to re-insert the key once more. No problem with Premier though and
I haven't tried with Rai yet to see if it opens when is scrambled.
Maybe this is the symptom with stealth 217?
I will try to downgrade to a previous version.
Thanks Mickha!
Old 25-10-2007   #15
I assume that's because the Diablo is trying to Auto Update the keys, and causing problems, only by using an early Stealth file can you open D+, until the team bring out a new Stealth file.
Old 25-10-2007   #16
Thanks Mickha, I will keep you posted.
Old 26-10-2007   #17
Diablo Light and D+ problems.
I have now staged down to stealth 2.14 and still get same results. I inputed the latest key manually. The channel will unscramble for about 70 seconds and then scramble again.
Has anybody else had same problems? How can I view the D+ programs?
What version stealth is best?
Mickha,
When I go to insert the key manually I noticed that there are three Digital+ s to choose from under Nagravision 2. I believe the providers are: 4001, 4101, 4102.
At first, I chose 4101 but then in desperation, I put the same key on all three of them. Which one should I have chosen?
Another thing, in the keys menu I find there is a "Nagravision Box Key" What is that for (there is no key there at the moment: 0000....).
Any help is appreciated (before I loose my mind)
Old 26-10-2007   #18
4102 covers MTV ESP, TCM ESP, and a few other channels so do not alter those keys.
4101 is the usual keys to alter, but this varies in some receivers.
For D+ try Stealth 215, if that fails you will have to try an early version like 203 or 204.
Ignore the Nagravision Box Key.
fortechd (26-10-2007)
Old 26-10-2007   #19
Stealth 218 has now been released which gives the option to turn off Nagravisin 2 AU, which should cure the D+ problem.
diablo, light, setup
