What CAM shall I use?CAMs, built-in CAMs, Common-Interface CAMs... | |
| Member Join Date: 03-01-2008 Location: Holland
My System: Motorized dish | Topfield TF5000CI | Diablo CAM | Canal Digitaal smart card | CAS 3+ Interface |
Hello all, Some times ago I bought a DVB-S receiver Topfield TF5000CI as I thought I could get TPS, Canal Sat, Canal Digitaal for free. I have read a few topics on this forum and it looks like only TPS would be available "for free". I am here seeking for help because I have a few questions:
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | No you wont get Canal Sat for free. You want it = you subscribe to it (or find a card share but thats a new kettle of worms) TPS is currently open on old key settings - they must be using some really ancient keys. Note we are expecting TPS to disappear at some point fairly soon. | ||
| The Following User Says Thank You to Analoguesat For This Useful Post: | roshii (04-01-2008) |
| Regular Member Join Date: 25-03-2007 Location: South West
My System: Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams. | The keys are known/out for canalsat (seca2) Astra1 19.2°E, but the Nano still remains unknown, so not much use unless you have a mosc card. For the money, I would get a Diablo cam and a Cas 3 programmer, although you will still not receive canalsat... Regards, Ollie | ||
| The Following User Says Thank You to v9oly For This Useful Post: | roshii (04-01-2008) |
| | #4 | ||||
My System: Motorized dish | Topfield TF5000CI | Diablo CAM | Canal Digitaal smart card | CAS 3+ Interface | Thank you both for your reply. It is a bit clearer now though I still have a few questions. Thanks for the advice, I will not invest in anything there then ![]() Do I need to subscribe to the full package or can I simply subscribe to the cheapest package and eneable every other channel afterwards?
| | #5 | ||
| Member Join Date: 23-07-2004 Location: arklow co.wicklow r.o.i.
My System: dreambox7000 | i have a t.rex/dragon cam and i am very happy with t and also cas3.the amount of programmes open o thor are {at the moment]amazing | ||
| The Following User Says Thank You to dublindanny For This Useful Post: | roshii (04-01-2008) |
| | #6 | ||
My System: Motorized dish | Topfield TF5000CI | Diablo CAM | Canal Digitaal smart card | CAS 3+ Interface | All, Can someone explain what is the main difference between Diablo, Dragon and T-Rex CAM? Which one would be the best option? What I want is something reliable and compatible. Thanks for any enlightment. | ||
| | #7 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | TRex is the new version of the Dragon. Bigger and better. More support. Dragons are getting a bit long in the tooth although they still have their uses at times. | ||
| | #8 | |||
My System: Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams. | Both cams are well proven, the Diablo has great support, regular software (Stealth) updates, guides etc, it is also a bit cheaper too. Don't hear as much about the dragon as I used to, but still a good cam, the recent version has a secure chip so the dragon team could release 'exclusive' hacks, but from memory this has only happened once (TV Cabo). Either way you go, the Cas 3 programmer will program both cams, again a well supported item, reliable and compatible. Roughly, the diablo & cas 3 is about £105 + delivery. Regards, Ollie | |||
| | #9 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
If you are going the official subscription route (might be quite expensive outside France), then buy the 12 months card with the maximum options that you can afford. You will not be able to make any changes to the package, so do be careful as you might ruin your card while experimenting and then you will not have any direct support since the dealer will not be able to help you once he has done the activation for the card for you. You might be able to open also the TPS channels on Hot Bird 13E, in addition to the Canal Sat channels on Astra 19.2E. Please report back on this point if you can. (TPS stopped supplying smartcards to subscribers since the merger with Canal Sat on 28/03/2007 so I expect they will stop transmitting on Hot Bird during April 2008). You will not be able to use any of the interactive services (only available with the Canal Satellite dedicated receivers) nor the PPV services or the adult options. May I ask why do you want the French package when you are entitled to subscribe to Canal Digitaal (Holland)? Are they not interesting enough? | |||
| The Following User Says Thank You to HB13DISH For This Useful Post: | roshii (08-01-2008) |
| | #10 | ||||
My System: Motorized dish | Topfield TF5000CI | Diablo CAM | Canal Digitaal smart card | CAS 3+ Interface | Thanks to your reply Ollie, I would go for a Diablo CAM with the CAS 3 programmer ![]() Considering this I wonder if it would not be cheaper to buy the CAM only, and just pay for the channels as it seems quite risky to modify an official card. Thanks again to all. | ||||
| | #11 | ||
Could someone let me know what is the main difference between the Astoncrypt 1.07 and the Diablo CAM light? I wonder because I saw the Astoncrypt for 60 € versus 85 € for the Diablo. Many thanks !!! | ||
| | #12 | ||
| Super Moderator Join Date: 10-12-2004
![]() | The Diablo light cam is one of the latest multi cams and can open available packages without thye use of a card. You will need a Cas programmer to update it with the latest Stealth firmware, I recommend the Cas 3+. I'm not sure what the Astoncrypt 1.07 can do but I would suggest you pay the extra and get a Diablo, unless you're only looking for a cam to work with a subscription card. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | roshii (08-01-2008) |
| | #13 | ||
My System: Motorized dish | Topfield TF5000CI | Diablo CAM | Canal Digitaal smart card | CAS 3+ Interface | Thanks Mickha!! Indeed would be stupid to get the Astoncrypt, I will get myself a Diablo and see what I can do with it. Thanks to all for your answers. Great forum | ||
| | #14 | ||
My System: Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams. | The Diablo cam is extremely popular at the moment, hence there are many discussions, guides and most importantly people to help you with it! ![]() Regards, Ollie | ||
| The Following User Says Thank You to v9oly For This Useful Post: | roshii (09-01-2008) |
| cam, canal sat, tps |
