Gigacam update
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 12-03-2008   #1
Gigacam update
How is the "GIGACAM" updated,with a card and infinity usb or card and cas 3?
peppey is offline   Reply With Quote
Old 15-03-2008   #2
Andrew007's Avatar
My System: Gregorian Motorised Dish: 62°E-45°W.. various STB's and LOTS of Goodies.!
GIGA CAMS..GREEN or BLUE..!!
peppey
There are TWO GigaCams..
1. Green Giga Twin Cam.(the First Generation)
S/W Update via CAS3 and CIS V:8.3
OR
S/W Update via GigaCam Loader Programmer.
Softcam Updated via GigaCam Loader Programmer.
also a little complicated way via the CAS/CIS Joker Method with the supplied Dummy Card and Serial Cable.
2. Blue Giga Twin Cam.(Second Generation with slightly larger Memory)
OR
S/W Update via CAS3 Plus and CIS V:8.3a
Softcam apparently ONLY via GigaCam Loader Programmer..!
OR
also the Other Method using the CAS/CIS for Joker Method and Serial Cable
Hope this answers your Q's m8y.
Cheers
Andrew
Andrew007 is offline   Reply With Quote
Old 15-03-2008   #3
Thanks,I thought it would be better than the DIABLO.
I use an infinityusb unlimited.
gigacam, update
