Beginner with a dragon Cam
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 22-04-2008   #1
My System: satellite
I have brought dragon cam from a friend and it works properly with TPS and Multi Vision. I want to know what list of channels that it work with and how to update it when needed.
My receiver is Humax 5400 and I receive hot bird and astra
thank you
khedr is offline   Reply With Quote
Old 22-04-2008   #2
Archived Member
thank you
You can make your own list by browsing the Hot Bird 13E and Astra, as nobody will do it for you.
http://www.lyngsat.com/hotbird.html
http://www.lyngsat.com/astra19.html
Remember to click on the P=Packages to see more encrypted channels.
Hope that another member will reply regarding the updating.
HB13DISH is offline   Reply With Quote
Old 22-04-2008   #3
The Dragon doesn't usually openTPS it is just that TPS have turned off their AES so most things currently open it, this shouldn't last too long though.
With the Dragon and Predator 366 you can open the folowing packages: Premiere 19E, Polsat 13E and Digi TV 1W, along with a few other channels.
To update the Dragon you either need a Loader Card and card programmer, or a Cas 3.
Mickha is offline   Reply With Quote
Old 23-04-2008   #4
is there any chance to open mct or sex view
Old 23-04-2008   #5
Not without a new Predator, or Predasaur file, and support seems to have dried up again, only kinkdink was providing us with new files.
Old 24-04-2008   #6
Predator
Thanks, My dragon Cam is reading ((predator 3.49)) and today it stopped to open TPS and some other channel.
Could you Please advise me to the best way to use this Cam
Old 24-04-2008   #7
The Dragon Cam will not open TPS, as this package altered its encryption, the only reason you could still view it was that they had turned off the AES and were using just the older encryption, I'm now guessing they've switched back as you can't open it, but I'm not able to check that at the moment.
If you upgrade to Predator 366 you can still open Premiere 19E, Polsat 13E and Digi TV 1W.
Old 24-04-2008   #8
How can I upgrade it ?
Old 25-04-2008   #9
You either need a loader card, Fun 7 or PIC F84A, and card programmer, or a Cas 3 programmer.
What satellite equipment do you have?
Old 25-04-2008   #10
My Satellite is Humax 5400
Old 25-04-2008   #11
Site administrator
Analoguesat's Avatar
You need to buy some extra equipment - starting with a programmer.
Analogue forever!
Old 25-04-2008   #12
thank you, I wonder if you can direct me to a user guide that contain full information
Old 21-10-2008   #13
onetruescot's Avatar
My System: Pace ds810xe receiver Dragon Cam 3.02 Dragon loader card showing ver 3.59 Dell latitude laptop High spec home built pc High spec media centre pc
Cool Complete Novice with dragon Cam + Loader card
Hello all,
I am new to all this + was wondering firstly how to update card or cam? I am pretty techy minded as i build PCs as a hobby.
The cam i have is version 3.02, bought from a friend and unsure if it has ever been updated, also loader card.. think he purchased it and never knew what to do with it really!!
additional info - inserted cam into my pace ds810xe receiver and it showed it had predator version 3.58 installed. The loader card has some pre-installed stuff on it, but I am unsure of where to go from here....
your help would be much appreciated
onetruescot
onetruescot is offline   Reply With Quote
Old 21-10-2008   #14
To update the Dragon Cam you will need a card programmer capable of programming your loader card.
There are two types of loader card, the Fun 7 and the PIC F84a, if it is a Fun 7 it will have it written on it, if it is a PIC F84a it will have Dragon Loader, or something similar, written on it.
If you really want to get a programmer for the future I would recommend the Cas 3+, as this can program both Cams and Cards.
You have not mentioned what satellites you cam receive, if you only have a standard mini dish for Astra 2, 28.2E, then you will not open a great deal, if you have a motorized satellite dish you can currently open the following packages with your Cam:
Premiere 19.2E, closing down very soon as they are upgrading their encryption to Nagra 3.
Polsat 13E
Digi TV 1W.
The Following User Says Thank You to Mickha For This Useful Post:
onetruescot (21-10-2008)
Old 21-10-2008   #15
Thumbs up
ok thanks Mickha for reply .. i do indeed have the dragon loader card and it seems to have had some stuff pre-installed on it when i go into the debug settings
however that seems a bit complicated to me just yet lol
i have a fixed (communal) sat dish, but its huge!!
I seem to get signals from all the satellites i have searched but granted, some have poor signal quality.
what is the next step i should take, do i need a card programmer like a cas3 to get the full potential of card and cam?
onetruescot
Old 21-10-2008   #16
Only if you can receive the satellites, and packages, mentioned.
You should be able to manually update the keys, go into the Cams menu, Debug, OhlAladin and the relevant provider, but I'm unsure if the channels will open using that predator version, but worth a try.
Have a look here for the channels currently available, try tuning tham in and manually updating the keys:
_http://www.lyngsat.com/packages/premiere.html
_http://www.lyngsat.com/packages/polsat.html
_http://www.lyngsat.com/packages/digi.html
Old 21-10-2008   #17
Wink Many Thanks!!
- Thankyou Mickha,
I will try as you mentioned to manually key in.
I will also invest in a cas3+ as you mentioned earlier
thanks again, your a star > * lol
Onetruescot
beginner, cam, dragon
