programing oasis cam?,same files compatible then on trex?CAMs, built-in CAMs, Common-Interface CAMs... | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! i bought on Ebay dont find much information on google!? maybe someone knows more? | ||
| Super Moderator Join Date: 10-12-2004
![]() | I can't remember hearing of the Oasis Cam but generally you can not use dragon/T-rex files on other cams, that also goes for the Diablo cam files. I have just done a search, for this cam, and the Oasis 2 Cam claims to be a multicrypt cam, similar to the Diablo and Dragon and has a lot of support files available on forums, some claim considering I haven't seen these files !!!!! I'll have a search and see if I can find anything. I've had a quick search and seen mention of these cams from 2007, but not much support and no files. I would advise you return the cam, or ask the seller to show you where you can find support for this cam. It seems the makers claimed that these cams worked with official S*y cards, but this also appears to be incorrect. | ||
| cam, compatible, files, oasis, programing, trex |
