Begginer with Diablo Cam lightCAMs, built-in CAMs, Common-Interface CAMs... | |
| Member Join Date: 13-09-2008 Location: HUDDERSFIELD YORKSHIRE
My System: PACE DS810X 80CM DISH MOTORISED |
Hi I have just recieved my new Diablo light card, but find my free to air stations will not work when the card is in place and whats more the card does not unscrabble the sports premier channel on astra 1. I left the card in all afternoon but no joy. I am using a pace DS810XE which does recognise the card. Any clues? Cheers Kellyjr | ||
Yes sorry i mean cam I think the problem is i need to upgrade the software on the pace box to 1.0.35 so am busy re setting the box and will try to download the new version. Never watched so little tele in all my life, but will get their. The learning curve is pretty steep for this lot. Thanks for the promt advice again | ||
| | #5 | ||
Hi Download the new software, but the cam is still not working and blocks all other channels. Underworld 132 is loaded and both N2 AU and Emulators on in the Configuration menu? Any ideas? Cheers Kellyjr | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | There have been problems getting cams to function correctly by the Pace DX10XE since it came out. Check the Pace HD section in this forum, particularly the sticky. Maybe a later software update may help. Llew | ||
| begginer, cam, diablo, light |
