diablo camCAMs, built-in CAMs, Common-Interface CAMs... | |
| Member Join Date: 10-01-2009 Location: fife, scotland
My System: TM 6800 HD, TD 110 dish motorised. |
i got myself a diablo cam with cas3 programmer today . can anyone tell me which satellites/channels i should be receiving?? | ||
| Super Moderator Join Date: 10-12-2004
![]() | At the moment mainly on 1W, you will need to load Underworld 164 or the latest Underworld 165, then you can open both the Canal Digital and Digi TV packages on 1W: _http://www.lyngsat.com/packages/canaldigital.html _http://www.lyngsat.com/packages/digi.html To open Digi TV you will need to either load an updated keys bin file or manually enter the keys. | ||
| | #5 | ||
![]() | Go into the Cams menu, using your receivers options, and enter the following sub menus: Underworld 165 Keys List Keys Edit Nagravisision 2 Digi TV Key 96 (Key 01) Press enter, or OK, depending on your remote, and select how you want to update the key, either Hexadecimal or Decimal, I find Decimal to be quicker. Enter the new key and exit. | ||
| | #6 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | I've found this list on certain forum, absolutely no idea is it true or not: TV Globo (13°East) nagra2 IDEEA key 86 (00) Euro1080 HD(7°E) (Irdeto2) MTV Unlimited - Astra 1M (19.2°E) Canaal Digital Nordic - Thor 3/5 (0.8°W) Da Vinci Learning (Smartcast) - Sirius 4 (4.8°E) | ||
| | #7 | |||
| Member Join Date: 03-01-2008 Location: W5
My System: Topfield TF7710HDPVR, Amstrad Sky, Stab HH100/RAD 1m Dish, RAD 60cm Dish (13E), Sky Minidish (28.2E), Diablo WiFi CAM, Sky Official Card, J*TV MOSC |
| | #8 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #9 | ||
My System: Topfield TF7710HDPVR, Amstrad Sky, Stab HH100/RAD 1m Dish, RAD 60cm Dish (13E), Sky Minidish (28.2E), Diablo WiFi CAM, Sky Official Card, J*TV MOSC | Hmm not really. Apart from DigiTV which I thought I'd added they're the major packages with a few channels of other packages open with older encryption, some BISS channels and some porn on various sats and that's about it. Do let us know if you know otherwise. | ||
| | #10 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | MTV package do works - friend, who owns diablo, confirmed it. | ||
| cam, diablo |
