force 1122
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 01-10-2001   #1
"Satellite Expert"
wolsty's Avatar
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface
force 1122
Hello from the newest member.
I have an analogue system with DiSECq 1.2, which I bought for £75 in France last year. I've learned a lot from playing with the kit but, since it's on the way out, I've decided to explore digital. I've done a huge amount of reading and searching the Web, but the more I find out, the more confused I get, particularly with regard to CAM's and receivers. I thought I might buy a Humax 5400 with a patch, but then I saw the Force 1122, which seems to be a more sophisticated bit of kit, has rave reviews and is cheaper than the Humax. I've read that the Force has programmable CAM's, but I can't find any downloads. Am I chasing rainbows, or would I do better to buy a 5400 while they're still available?
Geoff Wolstencroft
wolsty
wolsty is offline   Reply With Quote
Old 02-10-2001   #2
Honorary Admin
2old4this's Avatar
RE: force 1122
DiSEqC = Digital Satellite EQuipment Control. Surprised you have that on an old analogue system...
The programmable (embedded)CAMs feature for the Force should not be taken to mean that the CAM can be freely programmed with (eg) something like Amon of FreeCAM2. No doubt there are all kinds of safeguards built into the procedure.
Don't worry about the 5400. The new 5400z can also be patched once the loader has been replaced. Various people are working on a hardware interface which will enable that. Satnerds in Holland have already made and tested one (see http://www.satnerds.com/ ), and are talking to local satellite dealers to set up a network of shops that can do the upgrade. It will be mainstream pretty soon.
2old
2old4this is offline   Reply With Quote
Old 02-10-2001   #3
RE: force 1122
Have a 1122 with the yet to be released Betasoftware giving you both embedded Conax and Viaccess (http://johnsat1.gotoo.com/) thus leaving you with two slots for various CAMs like the hard to find Irdeto AllCam / FreeCam and even a SECA CAM.
The Humax 5400 is wonderful piece of kit giving you all these options with bit of software tinkering. The additional Dolby Surround capability makes it even more attractive.
Both good choices. The Humax is presently a bit to expensive to my liking. That might change, as 2old indicated.
Pligs
ua::yes
Pligs76 is offline   Reply With Quote
Old 02-10-2001   #4
"Satellite Expert"
wolsty's Avatar
RE: force 1122
Thanks, Pligs.
I think I've decided on the Humax.
Wolsty
wolsty
1122, force
Similar Threads
Force vs. DreamBox morten DISH SETUP: Single sat, Multi-Sat & Motorised systems 5 30-01-2005 01:56 PM
mr, force 1122, fun 6, error message tall_paul Matrix Reloaded, Revolutions and CAS interface 1 21-01-2004 09:55 PM
Force and conax sysrq Conax, Cryptoworks, Nagravision, NDS and Others 3 02-01-2004 08:22 PM
Force 1199s bjarte Viaccess 0 22-09-2003 10:11 PM
Force D-Master 1155 S problem fogerty4evr Viaccess 1 22-09-2003 10:04 PM
