Upgraded viaccess red cam and season interface problem
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 11-08-2001   #1
wakksa99
Posts: n/a
I had upgraded my older version of red viacess cam (477) to 481, and since then I am not able to make any kind of communication between the cam and interface, although I have tried different settings. Does any body know what is the problem and how can it be fixed?
Old 15-08-2001   #2
Honorary Admin
2old4this's Avatar
RE: Upgraded viaccess red cam and season interface problem
no, but I wonder why you upgraded something that was already working... These viaccess CAMs are tricky. You could very well find yourself with a CAM that will not work with any pirate card/software. It took ages for a 478-compatible hex to appear...
2old
2old4this is offline   Reply With Quote
Old 14-09-2001   #3
Red ViaAccess upgrade
My red ViaAccess cam was automatically upgraded via Hotbird.. I had no choice, all of a sudden I received a message: wait, downloading, do not remove CAM. Bye the time I figured out what was going on, the CAM was already upgrading.. I lost some of the channels (VH1, MTV, etc.)..
Any suggestions? How to prevent this from happening in the future, and how to return it back to its original state..
Thanks.
magomag is offline   Reply With Quote
Old 14-09-2001   #4
Honorary Admin
2old4this's Avatar
RE: Red ViaAccess upgrade
I'm astonished that this can happen "automatically". What kind of receiver are you using? Which frequency/pol/sr were you tuned to at the time?
2old
cam, interface, problem, red, season, upgraded, viaccess
