do i need CAM or PATCH ???CAMs, built-in CAMs, Common-Interface CAMs... | |
| Regular Member Join Date: 14-02-2005
hi do i actually need any CAM for Humax PVR 8100, or a patch will do? if a CAM is essential, which one does the best for Hotbird & Astra 19? Dragon or Magic? i'm completely new at this so please do explain it in a simple way. cheers. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Not sure that there is a patch for your Humax, so you will probably need a CAM, forget the Magic, it is now a tad old hat. There isn't much now to compare between the Dragon, Matrix Reborn/revolution/reloaded, X-CAM/Ultra and Reality CAM, they all seem to achieve similar results. | ||
| A bit enthusiastic Join Date: 11-02-2004 Location: Sweden
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | I have a 8100 PVR and I havent been able to find a patch for it,read on some page that a Hyundai patch should work in it,but I didn't understand the language on that page so I never downloaded that patch. If you should stumble over something,please post it here! | ||
| | #4 | |||
now, what do i exactly need with DRAGON to unscamble those channels on 13° & 19°, loader program ? fun card ? predator 3.07 / 3.09 ? what are the technical procedure of loading the software into the receiver? any certain version of DRAGON or they are all the same? would you recommend buying these at Ebay what would be the aprx price for all from a dealer? do you by the way have the list of the channels which can be cleared by DRAGON on Hotbird & Astra19? cheers. | |||
| cam, patch |
Similar Threads | ||||
| ne patch | megabit800 | Receiver software, international Section | 2 | 13-12-2006 08:54 PM |
| any hope for ma useless Irdeto CAM yet | sat_freak | Irdeto system | 7 | 10-05-2006 04:32 PM |
| diablo cam | wolfav | Cams and decoders General | 0 | 08-05-2006 04:28 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| Axas Cam and Dreamload | jderby | Cams and decoders General | 2 | 28-08-2003 05:52 PM |
